For those who took museum delivery, or delivery a great distance away, how did you follow the break-in procedure for your new C8?
Obviously there's no use of cruise control, hard braking, tight cornering, etc. But another recommendation is to avoid driving at constant speeds. Highways lend themselves to such driving conditions. Did you take backroads, exclusively?
Any other issues a new buyer should be aware of when going through the break-in phase?
I took exclusively back roads and it was a wonderful experience and the perfect way to break in the car. Spend some time mapping out your trip and enjoy the ride home.....
What was your mileage coming back? I'm looking at roughly 900 if I opt for the museum experience. Also wondering if I'm "in the clear" to drive at a more constant highway speed beyond 500 miles or if I should wait the full 1500.
If I remember correctly, I was right at about 870 miles home.
I'm sure you're fine too hit the highway, just vary speeds and gears. Remember, you're breaking in the DCT more so than the engine in a lot of respects. I would just encourage you not to miss out on the drive home experience - it's a great thing when you're in your new toy!!!
I used the highway and had no issues. I varied the speed and as per the museum's recommendation, I stopped every couple of hours for 20-30 minutes to let it heat cycle.
I drove backroads for the 280 miles home. Varied rpms and speed using Drive and Manual shifting. Varied between Touring, Sport, and Track throughout. Stopped about every 1.5 hours and shut it down while on a stretch and pee.
If I had to do a long distance I would use combo interstate and backroads.
Wife and I drove the car back from the museum to the Phoenix area--1800+ miles. We kind of took our time... We drove back over 6 days. Almost all highway miles... We drove around the Bowling Green area for a few hours. Stop and go traffic.... Stopped for a bite to eat. On the highway I tried to keep it out of V4. Probably not necessary, but I thought that it would be best to break it in while in V8 for the first 600+ miles. After that I started to use cruise control on the highway. We stopped a lot, not trying to time food, fuel and bathroom stops. A little bit of heat cycling I suppose. Car runs great. If I do this again in the future, I'll probably drive it the same way.
2nd thought of sorts.... If V4 was bad during the early part of break in, GM probably could have programmed it to not activate until after 500 miles or whatever number they wanted.
It' easier using back roads, and less chance of flying debris damaging your C8's finish, especially if the highways on your route are very busy where it can be difficult varying your speed.
I was 530 miles to home from Bowling Green up to West Michigan. Other than hopping on I-65 to get across the Ohio River near Louisville, I took two lanes all the way back and we had a wonderful drive. 25 mph? Check. 60 mph? check. 45? check. 55? check. Stopping in Smallville USA? Check. 20 mph through Anytown USA? Check. We hate interstates anyways, so this was right in our wheelhouse.
GM says to check the oil at every fill up, as the vehicle could use more oil than usual during the break-in period. Did any of you notice excessive oil consumption from the C8 during your break-in?
100% correct here I did the same and some interstate closer I got home.
And for break in I did a good bit of driving in manual so I can make sure to shift at the limited RPM range and to be able to shift around different RPM's when on interstate.
Yet another who drove back roads virtually all the way home. (Southern Ohio.) The direct route, using interstates, is about 250 miles. I figured out a non-direct route that made use of some twisty roads I know in KY and IN and stretched the trip to just under 400 miles, only about 15 of which was on I-75, and that was in the last 20 miles. Kept it in manual mode the whole way and tried out C8 style paddle shifting. (My only prior paddle shift experience was my C6, which wasn't really the same thing at all, including paddle operation.)
An advantage to back roads as a route home is that if there is a problem, it is a lot easier, and safer, to find a place to pull over and stop. Safer to proceed at a slow, careful pace too. I didn't need that, and hopefully you won't either, but it is a factor worth thinking about. I found a convenient station for a fill up at about half way (wasn't confident in the gas gauge as of yet) and found it was accurate. And when I lifted the engine cover to check the oil, I suddenly found half a dozen new friends. (All of them very curious as to why I was checking the oil with the engine running.)
Which reminds me of another advantage to back roads: The number of people that will smile, wave, and give a thumbs up.
I only checked my oil once during the first 500 miles but I was driving around town and don't remember stopping to fill up more than twice. I never checked it again until I hit my one year mark and took it in for an oil change. It was fine.
Totally agree with all of these posts. Travel the backroads (U.S. and state highways) avoid the Interstates. You get to see Americana in a way that you just can't on the Interstates. For our C7 NCM delivery, we drove the entire Natchez Trace Parkway and then headed to DFW via state highways. For our C8 NCM delivery, we first headed to Bardstown to visit some craft Bourbon distilleries. The headed back west hitting a variety of national scenic byways. We did the Ozark National Riverways Scenic Drive, the Boston Mountains Scenic Drive, the Northwestern Arkansas Scenic Byway, and the Talimena Scenic Drive in both Arkansas and Oklahoma. All of these were nice drives as were all the state and U.S. highways we travelled between the scenic routes.
