Engine failure follow up
So if your motor bricks let the SA know this sequence it may help expedite your repair
Good luck to the OP in getting your car fixed. I know how stressful these major repairs can be.
It does sound strange but location is probably due to that being a fire hazard.
Getting to battery is very simple. Remove the three amigos and you're there.
Most fuses are behind the "waterfall" between the two seats.
That probably damaged the starter motor as well as drawing too much current.
Starter is usually direct wired to battery via a fusible link due to the high current it carries. Starter has a solenoid / switch, and that solenoid is much much lower current and has a fuse in the regular fuse box.
Anyway. I think it is interesting that I have heard of more than one case where an engine failed / seized up and after they got the new engine in they ended up saying they had to also wait for a new starter.
Does this mean the new engine was shipped without the power accessories, starter, etc. and GM figured those would be taken off the original engine for re-use?
It would seem quite odd to me to have a NEW engine with a NEW starter installed and then immediately find out the new starter was bad. if that were the case, why wouldn't they just pull the old starter off the original engine and use that one to quickly get the car running again? Nope, they end up having to wait for a replacement to arrive.
That tells me they are likely re-using the old starter and it was damaged during testing trying to turnover the seized motor. That's my guess anyway.
So to me the lesson learned here is, if you get a seized engine, take out a sharpie and put an X on the starter. If you end up with the car back and the starter has an X on it, you might request they replace that starter because it likely was pretty heavily abused.
I would request this anyway, but marking the parts is my way of keeping folks honest!
