Sponsored by: Wheel Design
C8 Jacking Pucks
Old May 20, 2023 | 12:49 PM
davjes53's Avatar
davjes53
Default C8 Jacking Pucks
I have a set of JGR aluminum jacking pucks that I bought for my C7 from Amazon. I have a new Stingray coming soon and was wondering if anyone knows if these will work on a C8?
Thanks in advance.
Old May 20, 2023 | 01:14 PM
TD20's Avatar
TD20
I’m pretty sure these will work.
Old May 20, 2023 | 03:12 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Supposedly jacking pucks for C7 will work
Old May 20, 2023 | 03:35 PM
jim copland's Avatar
jim copland
I bought mine for my C6 & they worked for my C7 & also work for my C8. The thing that I have to remember is to remove them when I take the car down off my 2 post lift. I have forgot and drove a short distance but was lucky and nothing was lost. For that reason the ones that bolt in might be a good idea.
Old May 20, 2023 | 04:20 PM
Wing42's Avatar
Wing42
I have those exact same ones from Amazon. They work perfectly.
Old May 21, 2023 | 12:48 AM
There you go, no need to purchase another set of jacking pucks.
Old May 21, 2023 | 10:51 AM
2024VETT's Avatar
2024VETT
Ok, so I get the pucks installed, jack up the car. Where are you suppose to put the jack stand if you need to remove a wheel?
Old May 21, 2023 | 11:16 AM
RKCRLR's Avatar
RKCRLR
I use the locations that say "Do Not Lift Here" as jack lifting points which allows you to put stands at the official lifting points. You wouldn't want to use these locations when using a 2 post lift since the rear locations are close to the center of gravity and the car could fall off the lift but if you are only lifting one side of the car the rear locations are handy. Make sure to use pucks with locating features in the holes, you may need to grind down one side of the the "T" to get it to fit in the hole. I've always used two jacks when lifting the front or rear of the car this way but you could probably do it with one jack if you are careful (no guarantees).
Old May 21, 2023 | 04:13 PM
wrecker3's Avatar
wrecker3
I use Hockey Pucks !!! Less than 10 Bucks !!!
Old May 21, 2023 | 06:13 PM
Netsinah's Avatar
Netsinah
Check out this Forum thread to answer your question:
​​​​​​https://www.corvetteforum.com/forums...ck-stands.html
I bought the Rennstand but made the mistake of purchasing a Corvette jack pad, when it came with one already. If you pull the trigger on Rennstand, perhaps call them to confirm what you'll be getting with the Jack Stand itself, before you buy anything extra. Having said that, you can buy other brands of jackpoint jack stands and there are other ideas for you to consider on the thread above. Good luck!
Old May 21, 2023 | 06:58 PM
sTz's Avatar
sTz
I made the same and they work great. I also have a set of Reverse Logic pucks, which are similar to the OP. They also sell wheel lug guides, which come in handy.
Old May 22, 2023 | 01:31 PM
davjes53's Avatar
davjes53
Thanks everyone for your input. Glad to hear I don't have to buy a new set of pucks.
davjes53
To C8 Jacking Pucks
