"DCT Hydraulic System Flush"
Lastly, with the issues we have seen with the DCT why on earth would you bypass this step? I have had to have my DCT valve body replaced twice for solenoid/sensor related plugging issues. Others have as well. The flush is an essential step to attempt to keep debris out of the valve body and keep the DCT operating smoothly.
I realize you like to do your own maintenance. I do as well and is why I have a quick jack to do so. But I won't be changing my own DCT filter as I can't do the flush which the procedure clearly calls for - and there is no way in hell I want to jeopardize the warranty on the DCT with the issues we have seen with it.
and also, I enjoy doing my own minor maintenance work...Giving a big thank you to everyone who took the time & made the effort to send a reply (or wanted to). Those messages have correct content relating to the procedure, to the need & to the benefits of a DCT Hydraulic System Flush BUT I don't think actually answered / addressed my original question: "Is the DCT Hydraulic System Flush a mandated & required warranty required event - if yes - then show me the document". Like I said, the owner's manual made no mention of this important maintenance item.
The owner's manual tells you what the routine maintenance items are.
The service manual describes how: the procedures to be followed for those maintenance items.
The procedure defined in the service manual for the DCT filter change maintenance specifies the flush as part of this maintenance procedure.
1) I don't want to know HOW to do anything and I'm therefore not asking for the procedure!!
2) I do want to know where it states / documents that I need to have this "Hydraulic System Flush" done.
3) Lots of kind folks have taken their time and made the effort to post docs etc. showing the procedure - Many THX!!
Moving on. The 2020 Owners Manual (OM) is the only document regarding maintenance that was given to me as an owner / operator. On pg. 290, Footnote # 4, that OM states that I need to change / replace the DCT fluid every three years and also it says to change / replace the DCT filter. OK Fine By Me I can do that - no problem. And to be fair, at the end of Footnote #4 it adds these two lines: "This service can be complex. See your dealer". Well if it weren't for all the noise (music?) on this forum about a "Hydraulic System Flush" I would not have bothered to, ".... see your dealer". So a BIG thank you to the knowledgeable forum members who share their wisdom.
I don't currently own a 2020 C8 service manual but I'm considering buying one - eventually ;>)
As-to having the procedure completed at the dealer and then driving home to change the filter oneself, my only concern with that - and it's a relatively small one - is that if for some reason the procedure did dump a fair amount of debris into the filter to where the filter by-pass valve opened, then a significant amount of the debris could/would be washed off the dirty side of the filter and into the DCT; that would defeat all the benefits of the procedure and the filter at that point.
@bhvrdr Not to put too fine a point on it... but I refer you to pg. 220 of the 2020 Owners Manual for a detailed procedure regarding - YES - changing the engine oil & filter (of all things).
Last edited by Jacques Albrecht; Jul 14, 2023 at 08:48 PM. Reason: adding "engine"
@bhvrdr Not to put too fine a point on it... but I refer you to pg. 220 of the 2020 Owners Manual for a detailed procedure regarding - YES - changing the oil & filter (of all things).
There are many maintenance procedures not outlined in the manual of how to complete.
Changing the DCT filter is just one of them
The point is that the owners manual only tells you when a service is to be done.
The SERVICE MANUAL tells you (or the dealer) what that service includes.
The DCT filter change service INCLUDES the flush procedure.
At this point, I think you're deliberately refusing to acknowledge the facts. Every service listed in the owners manual includes multiple steps. Those steps are not listed in the owners manual, but in the service manual. The first step in the DCT filter change is to do the flush. Nothing difficult or complicated about that at all. It doesn't say "only during a repair," or "only when you change the fluid." Nor does it have any other qualifiers. The First Step in the DCT filter change is to do the flush. Period.
and I do understand the circular thinking.... BUT bare w/me here - THX. You see I'm expecting that my Owners Manual will actually: "Show Me When Important Maintenance Items are REQUIRED to be SCHEDULED & Done".Now about the circular thinking... The docs from forum members are from a Service Manual, so understandably those docs describe HOW to perform the Hydraulic System Flush process (The Procedure). The Owners Manual fails to mention when to have this maintenance scheduled (Where Is It Documented?). The emphasis is on the schedule not on the process.
The DCT is very expensive and its maintenance is very important - so I'm surprised that a Hydraulic System Flush event schedule is not mentioned as a necessary maintenance item in the only manual that buyers receive with their purchase of a C8 - The Owners Manual.
The manual says when to replace the DCT filter. It says it in a nice table and again in written language.
If you plan on doing your own maintenance it behoves you to know how to do them... which means becoming familiar with the service manual not just an owners manual.
Lastly, the DCT filter change does NOT require a flush procedure every time (thus the confusion).
You don't SCHEDULE a hydraulic system flush. It is a step that is required in changing the external DCT filter.
You already have the schedule for the DCT filter change.
I have no idea where you found an alternate DCT filter change procedure that doesn't require the hydraulic system flush but I have yet to see that.
The speculation was that the clutch’s where creating debris that GM wanted removed from the areas in the valve body. ???
And now we have this extra step before replacing the filter.
