C8 AFM Disable?
lol...irony is thick...
For real though...
I do agree the problem is minimal with the c8 on the afm but its not that great on other GM engines.......but I'm sticking you can't verify a real fuel savings and cost add justification on any of them...but its ok...you like grape kool aide its all good...
This. GM didn't spend tens or hundreds of millions developing the technology, and further millions buying millions of complex parts, because it doesn't work. How big a gain is going to be dependent on a lot of factors, many related to the driver, but especially on the highway the benefits are real.[/QUOTE]
Link to where they spend hundreds of millions of dollars on that crappy AFM design..
They need a refund..
and for the record my evidence is my actual test...I tried a month never using it and a month using it normally and there was zero difference using very close to the same mileage and routes and drving and gas station down to the same pump... C7a few years ago...Internet is full of peeps that have defeated them with no apparent change in efficiency before and after MPG...very tiny gain of any...< 1mpg imo regardless...
Its evident have not kept up with the history of GM **** ups...the list is long....
I'm out though...Here is to hoping your car never eats itself because of AFM failing...
I still don't see any valid cause for the "extreme engine damage" or "destroyed engine" that people claim from failures of the system.
I agree that hydraulic lifters do fail, rarely. And that's been true long before anyone at GM even dreamed of AFM. Had it happen on my dad's 66 Dodge. I agree with the statement that people who have a lifter failure, and often any other top end issues, like to blame it on AFM. I talked to one Chevy dealership mechanic who said lifter failures happen about the same amount on regular and AFM lifters.
Metric **** ton of irony that you say there is no irony....The answer to post 434 was not ignored lol...the answer obvious...the same exact reason they put auto stop start....EPA bowing to climate whataboutism and mandating idiocy....but hey you don't see irony either so I shouldn't be surprised you didn't know...
You win...
Hopefully yours don't puke as well....
Don't get me wrong, there isn't any evidence that the LT engine AFM lifters fail at a significantly higher rate than non AFM-lifters, nor not using the system once installed prevents its failure.
You win...
https://www.youtube.com/watch?v=gEcxI2nwwxE
I knew that oil pressure controlled the lifter collapse event, but I did not know that pressure causes it to collapse, absence of pressure causes it to lock (not collapse). Again, it seems like if its never activated - it would just remain locked.
Just asking.
Just asking.
But one thing I am trying to figure out at first, I swear there was some rough running when loading a Gear in manual mode. So say 1500 rpms in 7th, and give it heavy throttle to load accel some without down shifting. If I remove Carbith it pulls smooth, with installed I can feel some non smoothness.... at least I think... more testing but welcome someone else seeing if they notice it or maybe it was just me getting use to the car after not having it for a few weeks. Also car was learning trans so maybe it was related, maybe the gas after sitting for 4-5 weeks for new trans was not up to the task of that load.. More testing but it works on 2022.
I will say when the car wants to swap to V4, it never does BUT the AFM valves shut and then open. I have a track exhaust with AFM valves so you can tell when it flicks shut and then back open.
"The new dual-clutch transmission, however, has less inherent capability
to mask engine vibration, which is why cylinder-deactivation technology
has so rarely been used on a car with a dual-clutch transmission. The C8
engineers were able to marry these two technologies in the new Corvette,
however, by putting some micro-slip into the clutch control of the DCT.
As a result, those transitions are almost imperceptible, or as Kociba claims
“butter-smooth.”
All exhaust passing thru those small holes has to incorporated with the small clutch slip Tadge Juechter said occurs with the V8/V4 transition (when all is working properly.)
Let me clarify.
The AMF valve you can hear shut and instantly open. Probably does not even close all the way. I just happen to have loud track exhaust so when V4 would normal change over, I can hear the AFM valve change the note for a split second... then its back loud. This has NOTHING to do with the smoothness I was asking about. The car not switching in and out of V4 in auto mode around town is much smoother in that aspect, no changin in and out and has V8 even when lugging it around and pulls small kills with out it kicking in and out of V4/V8.
The smoothness that I questioned was in MANUAL mode. so V4 was not active anyway. You can not load a gear in auto mode it will down shift as engine load increases.
So in Manual mode, 7th gear 1500 rpms. load the motor heave with accelerator, THIS is when I felt the motor was not as smooth as normal. But maybe it was older fuel, maybe it was just the hew trans, the roads, I don't know. Most testing will be needed. But figured I would ask since there is a thread of people playing with the same part.
