Evening! Changed engine/trans oil and filters myself at 1600mi, just because I wanted to. Sent in the oil samples to Mobil labs. Engine oil was showing some fuel dilution. Mobil can’t test the Trans fluid, so no results there. I figured the silicon would be high (adhesives, sealants and castings), but I was surprised at fuel. Anyone else sample the first change and experience this? Just sharing as an FYI for my forum friends.
The sampling data indicates this is a 5.5L which means your car is a Z06, yet the test sample is listed as 0W-40. The factory fill on a Z06 is 5W-50. Which do you have, a Z06 or a Stingray?
His public profile says 2023 Stingray, so it would be 6.2L and 0W-40 oil. It is possible that the oil sample was not taken after the car was fully warmed up which would give the fuel residual in the oil to "evaporate".
The high silicon level on a new engine can be from the hypereutectic piston material and the sand casted block. The fuel in the oil is most likely from the overly rich conditions that occur during high load operation. All modern engines that run high compression will use a low AFR to reduce combustions temp.
