Sponsored by: Wheel Design
ceramic coating flashes immediately
Old Sep 2, 2023 | 01:56 AM
brown007's Avatar
brown007
Default ceramic coating flashes immediately
<edit>Avalon King Armor Shield IX<edit>
coating flashes seconds after applying. shortest time to wait in instructions is 30 to 60 seconds.
new factory paint, in garage, 80 degrees f, and medium humidity.
i tried a second coat with different bottle. same immediate flash.
proves not surface of paint?
i cross hatched over the flashed product until realizing something is wrong.
is product defective?
Last edited by brown007; Sep 2, 2023 at 02:44 PM. Reason: need to know brand but I want to hide it
Old Sep 2, 2023 | 07:12 AM
Fishfryer527's Avatar
Fishfryer527
I used Gtechniq CSL, it took about 30 seconds to begin looking like little droplets formed. Have you looked at youtubes on the product? After that I’d call or email customer service. I used two types of ceramic coatings, both simple, worked great. I’m in Florida, so we typically have higher humidity.
Old Sep 2, 2023 | 07:33 AM
449er's Avatar
449er
CF Community Team
What brand of ceramic coating are you using?
Old Sep 2, 2023 | 01:56 PM
OP - it would be helpful if you mentioned which brand of ceramic coating you are using.
Old Sep 2, 2023 | 02:01 PM
24/Eray's Avatar
24/Eray
Under those conditions I see now issues with flash over happening in that time frame.
Old Sep 2, 2023 | 02:41 PM
brown007's Avatar
brown007
Avalon King.
Called tech support but seemed 1st level reading from script. No help. That's why I'm here.
"Did you shake the bottle?" "Did you do small 2ft x 2ft sections?" ...
Old Sep 2, 2023 | 10:10 PM
Fishfryer527
I used Avalon King for the first car I did… worked great, didn’t flash quickly at all. It was November in Florida, so not to hot. The product worked great. I switched to Gtechniq CSL after that just because they seemed to be have a better line of products.
It sounds as though you got a bad batch.
yes definitely defective.
Old Sep 2, 2023 | 10:40 PM
Maxie2U's Avatar
Maxie2U
What is flashing for those of not up on ceramic coating?
Old Sep 2, 2023 | 11:04 PM
scithera's Avatar
scithera
When the solvent evaporates. You'll usually see a rainbow effect with most coatings which tells you it's time to wipe away the excess and level it out.
Old Sep 3, 2023 | 12:16 AM
Avanti's Avatar
Avanti
Sorry to see, but did anyone recommend it? Have you contacted the company? You didn't try a new product on a small, subtle area first? ALWAYS do so!!! All the best, in any event.
To ceramic coating flashes immediately
