DCT transmission filter
Again, class action lawsuit the minute they deny ANYone warranty because maintenance not specified in the owners manual was "missed".
Having said that, it isn't a question of changing the filter if one knows about the requirement. There is nothing in the owner's manual that states the DCT filter maintenance can't be treated like any other maintenance interval and people that don't follow C8 social media wouldn't know about the requirement.
The +/- 500 mile window was added only this year to the procedure (the date at the bottom of the page from the service manual says 2023). Prior to that we have verbal statements from GM reps at public forums that if changed early (3000 miles) it needed to be changed again at 7500, but with no statement of the grace period on either side. It then appeared in tech-link article, again without the grace period. Some suggested it was a mistake, or member were reading too much into it -etc. The addition of this information in the procedure seems to indicate that GM is doubling down on the requirement to be done very close to 7500 miles. And the additional note in the new procedure about changing the filter first, if past the service interval, before doing the hydrualic system flush, suggest that GM thinks those filter are really, really close to full when changed at the specified intervals. Again, I am glad this info was posted and discussed here.
No one has reported a warranty denial related to this issue being discussed. But it still might be relevant to the health of the transmission. I think it is.
What I object to is the implied (and apparently real) possibility that I'd have a warranty denial on the DCT because I maintained the DCT thoroughly and more frequently than specified in my owners manual that was supplied with my car upon purchase, but didn't complete one between 7000-8000. There's been no formal notification from GM to owners.
👉 Ostensibly, from the information presented thus far in the discussion, I could pay a dealer to do impeccable DCT maintenance at 3000, 6000, 9000, and get a warranty denial at 10,000 "because you didn't do it between 7000 and 8000". Without formal notice from GM to owners, that would be ridiculous, and therein lies the "bullshit".
Until or if there are warranty denials for the scenario above, I hope this all becomes moot, and they do the right thing. That even dealers are a little confused by this, says everything.
FWIW, my dealer did the DCT flush/filter, fluid replacement and engine oil/filter for $880 total, parts and labor. That was with me providing all GM parts/fluids and they did the labor.
Follow your manual in regard to maintenance! Don't try to be an expert and change the maintenance schedule because u think u know more or because of some post on Facebook or the Corvette Forum.
if u change earlier ir more open fluids/filters it's your decision but still follow the manual in regard to maintenance
The main difference with the use of "at" in the example above is that is still within the engine break-in period. If "at" is used within the break-in period then it triggers me to know that is a special break-in requirement. There isn't anything in the 2020-2022 manual that indicates the DCT break-in isn't complete after 1500 miles.
if u believe in Risk Mitigation you follow the GM maintenance schedule or convince them they are wrong
But I do agree - there is no evidence yet of anyone that has been denied a claim because of a failure to change the DCT filters within that window. The "warranty claim" concern, of course, is not the only issue. There is real indication (now anyway) that specified interval is about protecting the transmission. I with you that technically, if you changed at 6K you should be able to go 7,500 more miles at least (and more actually).
After his discussion I decided to ask GM a fourth time and forwarded them a copy of the page in the service manual that has the 7500 +/- mile requirement. I'll report back on if they quadruple down on their earlier answers or if they change their tune.
Automatic Transmission Fluid Filter Replacement - External Canister FilterNote:
- If the canister filter is replaced more than 500 miles prior to the 7500 mile break in period, the filter still needs to be replaced again within 500 miles +/- the 7500 mile service interval in the owners manual.
- The transmission maintenance schedule needs to be restarted when the transmission assembly is replaced. The new unit will require the same initial break-in maintenance.
FROM GM TECHLINK: Dual Clutch Transmission Canister Filter and Maintenance Schedule – TechLink (gm-techlink.com)
EDIT. In case anyone doesn't believe:
And its no rumor, that the information found in the owners manual is pretty clear about damage cause by failure to follow the service intervals may cause damage that may not be covered by the warranty. And, its no rumor that the procedure itself, and related tech link articles, which are what the dealers actually use, are even more clear about it. And its a fact that this extra info is not well communicated to owners. So, even though I see the perspective that its not well communicated, it would not be surprising to find someone post a denial of a warranty claim under the circumstance I posed above.
The problem is that for every other maintenance item if you do it early, there's no issue with it. If the DCT issue is different, then GM should make it CLEAR that it is different. And they have completely failed to do that.
