Sponsored by: Wheel Design
Floor Jack
Old Oct 30, 2023 | 07:41 PM
DEC8's Avatar
DEC8
Another vote for HF but mine is a low-profile 2-ton Pittsburgh model.
Old Oct 31, 2023 | 07:22 AM
Ozarks 70th HTC's Avatar
Ozarks 70th HTC
I understand where I need to place the jacks (with pucks) to raise the front and rear. Where do I then place jack stands on both ends so I can safely remove the jacks and not damage anything?
Old Oct 31, 2023 | 07:39 AM
jthornton's Avatar
jthornton
Originally Posted by 1 STING
Arcan, 2 or 3-ton, low profile, 3 1/2", rises 18 1/2", sold at Home Depot. Very well built, got both. The 2-ton is on sale for $120 from $152.
George
I was going to buy another Arcan 3 ton low profile jack as the one I have is great... then they went and started painting them puke green.
JT
Old Oct 31, 2023 | 07:44 AM
tsigwing's Avatar
tsigwing
That's the issue. There isn't anywhere. That is one of the reasons I went with a quick jack.
Old Oct 31, 2023 | 09:26 AM
RKCRLR's Avatar
RKCRLR
I use the locations in the frame with the round holes (the ones you aren't supposed to use when using a lift) so I can place the jack stands in the official lifting locations.
Old Oct 31, 2023 | 11:08 AM
Steve Armstrong's Avatar
Steve Armstrong
Originally Posted by Kracka
1.5 tons = 3,000 lbs
You'll never have that much weight on a single jack when using it under a Corvette. For most work on the car, I'm using 2 jacks and then of course jackstands if I'm going underneath it. They lift plenty high enough for oil changes, DCT filter/fluid changes, swaybar swaps, brake jobs, tire rotations, etc. These ones do not go high enough for anything Jeep-related though.
I've had 3 of these jacks throughout the years (~15?); the first one eventually wore out on me and would no longer lift a car. I use mine a fair amount though, quite a bit more often than average.
Originally Posted by HRDTOPC54FUN
Another vote for the 1.5 ton Harbor Freight aluminum. Lightweight, easy to move around, more than adequate capacity.
Thanks for confirming.
Old Oct 31, 2023 | 12:58 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Been happy with my 2 Harbor Freight jacks. Neither are currently available, but one is a long reach, the other a short reach aluminum that's light in weight and easy to move around. All depends on your needs.
Old Oct 31, 2023 | 11:49 PM
1 STING's Avatar
1 STING
Originally Posted by jthornton
I... then they went and started painting them puke green.
JT
Soo... if Salma Hayek winks at you and wants to sit on your lap but she is sporting a puke green bikini, of course you would turn her down.
Old Oct 31, 2023 | 11:50 PM
winders's Avatar
winders
What bikini??
Old Nov 1, 2023 | 01:33 AM
phalse's Avatar
phalse
https://www.harborfreight.com/automo...nge-64241.html
no, this one, you amateurs =D the long reach model is the way to go.
Old Nov 1, 2023 | 06:15 AM
jthornton's Avatar
jthornton
She seems to prefer red bikinis but looks best in a blue bikini. My wife is from Puerto Rico so no she can't sit on my lap.
JT
Old Nov 1, 2023 | 09:44 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
I have 4 jacks, all Harbor Freight. 1st one bought in 2000 when I built my street rod. Latest, a long reach about 4 years ago. It was only ~$100 at the time. My small Race Jack only ~$50. Boy prices have increased. Only thing to watch out for is all jacks MUST move it as you lift to keep the Jack Saddle directly under the C8 Frame Lift pad. Small Jacks with short Jack Arms must move in more. My 3 recent jacks fit under the 2-inch-high jack pads i have. The 1st (large orange below) only clears my 1" high jack pads.
Keep in mine never get under a car with just jacks. Only use jack stands (and those only one end at a time) or wheel stanchions. i have both. These stanchions are 12 inches high, takes a 2-step jacking process. Don't use those on Vettes. PIA no need.
Use these I made these two from a 12 foot board and some plywood I had for the top for ~$10. Can use a 2X8 12 foot long for the C8. Heck even wood has gotten very expensive! Changing oil on my prior C7 Grand Sport.
Old Nov 2, 2023 | 01:57 PM
  #33
Broken Halo's Avatar
Broken Halo
Early Black Friday sale just started today on a Husky 3 ton ALUMINUM jack for $159. https://www.homedepot.com/p/Husky-3-...530068#overlay
Old Nov 9, 2023 | 11:28 AM
  #34
Steve Armstrong
Here another one from Home Depot: 3-Ton Low Profile Car Jack with Quick Lift in Blue, Green, or Orange for $129
https://www.homedepot.com/p/Maasdam-...-DIP/314137064
Old Nov 9, 2023 | 06:11 PM
  #35
C5racecar's Avatar
C5racecar
Low profile is important. Aluminum is good, if you ever pack up and go to the track, some of the steel jacks are really heavy.
Funny thing about racing jacks. They say 2 pumps to full height. If you watch the NASCAR guys, the jack man is always the biggest guy on the team.
He slides the jack under the car and drops all his weight on the handle. Sometimes their feet come off the ground. The car goes up fast.
Fast forward to me in a tight garage, with a racing jack. It takes a lot of weight on the jack to raise the car.
Old Nov 9, 2023 | 06:14 PM
  #36
wrecker3's Avatar
wrecker3
I have a Arcan 3-Ton Quick Rise Aluminum Floor Jack. I got it back in 2016 for my 2016 C7.
Old Nov 9, 2023 | 07:40 PM
  #37
ZipZap's Avatar
ZipZap
From: A sympathetic, well-meaning, elderly man with a poor memory
St. Jude Donor '07-'08-'09-'10
Those aren't stock racing jacks...
I have racing jacks and standard jacks. The racing jacks are much lighter, but don't have any huge jacking advantage/disadvantage.
I'm rethinking jack stands on the C8. Have plenty of them but replacing the jack looks problematic. Don't want to commit to a QJ but options that leave the wheels accessible are limited.
To Floor Jack
Old Nov 9, 2023 | 08:46 PM
  #38
JerryU's Avatar
JerryU
Have 4 jacks and many pairs of Jack Stands as well. Bought this small base one so I could use as Big Lebowski did to lift high when removing the front calipers to change pads.
Narrow Base right from Walmart, ~$10.
What Big Lebowski did to lift front high to remove brake calipers.
This should also work if jack carefully.
Old Nov 12, 2023 | 05:24 PM
  #39
ZipZap's Avatar
ZipZap
Interesting. Don't think I've heard this previously. The pads hang below the body panel, yes? My good jackstands are aluminum a-frames. I was noodling through how I might use them, but having a second lift point would be great. Is this present on both front and rear?
Old Nov 12, 2023 | 06:04 PM
  #40
JerryU's Avatar
JerryU
Interesting. Don't think I've heard this previously. The pads hang below the body panel, yes? My good jack stands are aluminum a-frames. I was noodling through how I might use them, but having a second lift point would be great. Is this present on both front and rear?
Big Lebaowski posted a year or so ago. I asked if I could use his pic in my How To change brake pads PDF and he said sure. He and others where I used their info ate sited in the pic/long caption PDF.
The front is not an issue. The rear also has those round hole but there is a balance issue. I would use the jack where GM specifies and the jack stand where the round hole is located. If just changing brakes no need to jack higher than to remove the wheel. But on either end I would use two jacks and as I did for my C7s keep sight tension on the jacks after they are holding the full load.
Yep there are round holes in the back but be careful. Not lifting at the GM defined oval lift slots the car could tip! I'd use two jacks with pads on the GM oval lift slots and jack stands on the round holes.
As I did with my C7's even though I used jack stands (in that case under a cross member) I always keep the Jacks in place with slight tension. Not I also followed the advise on pair of jack stands (see below) and only used on one end of the car. I use wheel stands on the other.
I follow the advise of the pair of jack stands I have and NEVER get under the car with jack stands on both ends. Worked with my Dad from when I was ~8 doing brake jobs, replacing mufflers etc. He had a firm rule that after we put the car on solid supports on the frame (all cars had frames in the 1950) I had to hit the car hard with my shoulder. As he would say, it it's going to fall best it fall now not with you underneath! Using that rule no way would I hit the car hard on 4 jack stands. Two, two jacks with slight tension and the other end on wheel stands is the only way I'd get under the car!
