Sorry if this has been covered.
Why does GM install brake pads that create huge amounts of dust on wheels, when there are pads available that do not produce much if any dust.
Funny how this has turned into a hate fest.......Z51 vs non-Z51. If you want Z51 get it, if you don't then don't.......the car is fantastic either way.
I'm assuming you have a Z51. GM markets the Z51 as track capable so they need to use brake pads that are capable of withstanding a track environment. I'm not aware of any conventional track capable brake pads that don't create a lot of dust (or have other street issues). There are ceramic rotors but those are big bucks and have other issues.
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
Z51 Brembo C8's are know for excessive brake dust and was that ever so true for me. My first mod Carbotech Low Dust.
As to why, come's down to Performance, Philosophy's and Cost.
Thanks guys. I have a Z51 ordered. Guess I’ll be seeing lots of brake dust.
Only if you want to...... Lots of folks swap out pads for low dust versions. If you plan on lowering your car, change the pads while you have the wheels off.....
Why would GM put a racing pad on a car thar 99% of the buyers will never track and wear out quickly? Could bet your left nut it has more to do with the cost savings for GM than a benefit to the customer. That filthy dust you see is your cheap pads wearing out before your eyes. IMO.
Not necessarily, I've driven normal street pads until they had so much fade they wouldn't stop the car. The Brembo pads on the Z51 will tolerate far more heat than a conventional pad. I absolutely abused them at Spring Mountain and never ever lost any braking. A non Z51 pad would have been toast in a few laps.
Z51 pads work as designed. Very good pad for use on the track with factory tires. They also work well on the street. The dust is expected with this type of pad.
I got 4 track days and 17,000 street miles out of the oem pads. That is better wear than many expensive aftermarket pads that I have used.
It sounds as if you are one of the 1% that track your car. The option should be to install racing pads if that is how you will use your car. Not to pull the racing pads to have a good pad for the street as this is how most of the buyers use the car. Sounds like you burnt up street pads on the track? Seems like a lot of Z51 pads are being taken off the cars and trashed for low dusting quality street pads. I just tossed my Z51 pads in the recycling bin a couple of days ago.
They aren’t racing pads. They are a mixed street/track day pad. Z51 is a performance package. None of it is to improve low-performance needs.
You could have easily sold your pads to a track rat to offset the cost of low dusting pads. They often purchase used takeoff pads because they burn through them so fast.
That's true, I've seen a few set's sell through our CF parts sub forum. Always a fun place to visit.
Gm put those pads on a Z51 which is the package you should have if you are going to track the car and or drive it hard, now if that wasn’t your intentions with your car then why get that package
Z51 is a track package. If you do not want parts that were designed for the track, you should probably not order Z51. The brembo pads that come on z51 cars are not cheap by any means ($640 for brembo z51 pads on Rock Auto). They are designed to shed their lining in order to dissipate heat. The lining being shed creates dust but they do what they were designed to do. They will stop the car better on a track environment (or street environment for that matter) far better than a ceramic alternative that makes far less dust.
If you insist on having Z51, but don't want the dust, simply change them out.
Enough with this fallacious argument. Using your logic one could argue there is no point in getting a C8 Corvette if you are driving it only on the street as you can't possible use it capabilities...and least not legally. I think you guys use this argument to make you feel better about not getting the Z51 package.
The Z51option is a performance package, not a track package. I will probably never take my C8 to the track and wouldn't even consider buying it without the Z51 package. Everything in the package makes it a higher performance car.
Without the Z51 package you get a high performance street brake setup with hardened rotors and ceramic low dust brake pads and resulting long life.
You also get all season tires. Your choice.
