Dexos2
Not a big deal to use either but why not go the latest and greatest, dexosR, 0W-40 Mobile-1 Supercar oil.
People on the forum just shown that you can get it on Amazon.
Using the ESP X3 in your 2023 or later isn't going to hurt anything either.
Here is the exact wording from the gmdexos website.
"Please note: GM dexos 2 is being discontinued in 2025 and replaced by GM dexos D and GM dexos R. Vehicles equipped with diesel engines that used GM dexos 2 engine oil will use GM dexos D licensed engine oils, while vehicles equipped with gasoline engines will use GM dexos R licensed engine oils of the of the appropriate viscosity grade at their next oil change." and "Please note: GM dexos R engine oils meet or exceed the performance of GM dexos 2 and GM dexos 1 Gen 2 and Gen 3 oils and are backward compatible, therefore vehicles equipped with gasoline engines that used GM dexos 2, or GM dexos 1 Gen 2 or Gen 3 may use a GM dexos R licensed engine oil of the appropriate viscosity grade at their next oil change."
The gmdexos site currently lists 99 motor oils that are licensed under the dexos 2 specification. I checked several and the ones I checked are recommended for passenger cars, light trucks, gasoline engines and diesel engines. Mobil 1 ESP x3 0W-40 (not to be confused with Mobil 1 ESP Formula 0W-40 which became Mobil 1 Supercar 0W-40), is dexos 2 rated and compliant with the 2020-2022 Corvette Owners Manuals, but was actually developed for European gasoline engines according to Mobil 1: 'Mobil 1 ESP X3 0W-40 is our latest technology developed in cooperation with Porsche, one of our key European Original Equipment Manufacturers (OEMs). Mobil 1 ESP X3 0W-40 has been expertly engineered to help prolong the life in new emerging gasoline powered European vehicles." There are articles out there that say "GM designed dexos 2 [which is only a specification] for light duty diesel engines" but the fact is it is recommended for use in some European gasoline engines. Note that Mobil also says vehicles equipped with gasoline engines that used GM dexos 2, or GM dexos 1 Gen 2 or Gen 3 may use a GM dexos R licensed engine oil of the appropriate viscosity grade [if there is one - right now only two are made 0W-40 and 5W-50] at their next oil change.
"GM has found that using substandard oil can affect engine performance and, in the worst case scenario, may damage or harm the engine. Only licensed dexos® products have been certified by GM to meet the dexos® specification. Unlicensed products have not gone through GM's rigorous testing process, are not monitored for quality, and are not approved or recommended for use in GM vehicles. Unlicensed product quality and suitability for GM vehicles cannot be guaranteed and, therefore, use of unlicensed products may result in lower levels of performance and could cause engine damage that may not be covered under warranty."
As I mentioned earlier, I count 99 different motor oils licensed under dexos 2, and 36 different suppliers. Of those Mobil 1 (Exxon Mobil) supplies 10. Chevron (Havoline) supplies 9. Castrol supplies 13. Interestingly, GM is listed as supplying 11 different 5W-30 motors oil, 10 with an ACDelco name, and one called Pecas Genuinas GM Sintetico, The remaining 56 motor oils meeting dexos 2 are made by the other 32 suppliers (some familiar names, some not so much).
While GM may specify a dexos approved motor oil for cars it delivers to the European market (Corvette being one of them), I do not know if other European car makers also invoke a dexos requirement. They might, but European car makers (like Porsche, Mercedes Benz, VW) can and do write their own specifications as well. For example besides meeting dexos 2, Mobil 1 ESP x3 also meets Porsche C40, MB229.51, MB229.52, VW511 00, according to the Mobil 1 product data sheet. The Mobil 1 Supercar 0W-40 pds currently only lists dexos R under Specifications and Approvals.
So, given that dexos 2 is just a specification, what exactly does it mean to discontinue it? I assume GM will stop accepting oils for certification under the dexos 2 spec, but do the licenses granted under the dexos spec expire? What happens to all of those dexos 2 licensed motor oils? Do they just stop displaying the dexos 2 icon. Do they submit the product for approval under dexos D or dexos R as appropriate? What happens to Mobil 1 ESP x3 0W-40 in particular - it is specifically for gasoline engines, not diesel (according to its pds). Will it be approved under the dexos R spec? Although we know that Mobil 1 ESP Formula 0W-40 which was licensed dexos 2 became Mobil 1 Supercar 0W-40 licensed dexos R, it does not mean than all dexos 2 motor oils for gasoline engines will meet the dexos R requirement.
