Sponsored by: Wheel Design
DCT on cold startup
Old Nov 26, 2023 | 11:49 AM
Wormwood's Avatar
Wormwood
Default DCT on cold startup
I admit, I'm very green to this kind of powertrain but when the vehicle is started cold & after the engine heats up the O2 sensors & idles down, I shift to Rev & back out of the garage. It feels like a high stall torque converter & doesn't feel like its actually connected. Another way to explain it is like I were slipping the clutch if it were a standard. Anyway is rolls out in reverse & I put it Drive & leave. It still feels the same but not near as bad & by the time I'm at the end of my driveway (1/8th of a mile) everything is fine. The concern is the initial reverse really is soft/mushy & it doesn't seem to matter what the rpms are.... 2k rpms will get you the same as 1.5k rpms & so on.
Is this normal?
2023 C8 Convert. Z51 MAG NPP
~2000 miles
Old Nov 26, 2023 | 11:53 AM
Phil1098's Avatar
Phil1098
Does it "creep" in both reverse and drive? I.E. will it move on its own in reverse at idle with you just taking your foot off the brake pedal. When we did a fluid change and it was a bit low (no codes or sensors tripped) I lost my creep. I added some DCT fluid and it was back and acted "normal" again.
Old Nov 26, 2023 | 03:54 PM
Red C8 of Jax's Avatar
Red C8 of Jax
Normal
Old Nov 27, 2023 | 06:41 AM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
Normal. It was a little weird for me too at first. Then I realized, it is an automatic-clutch and does feel a little like a manual transmission.
Remember there is no torque converter which allows for slipage.
I am amazed at how well the engineers programmed and control the engagement and shifting of the gears.
Well not GM!
To DCT on cold startup
