Sponsored by: Wheel Design
Question on Soler Throttle Controller Bluetooth Functionality
Old Feb 10, 2024 | 10:39 AM
Car Junkie 24's Avatar
Car Junkie 24
Default Question on Soler Throttle Controller Bluetooth Functionality
Somehow the search function in this forum for "soler" doesn't show the existing threads for the Soler Throttle Controller, so starting a new thread.
I had a question before I purchase their throttle controller- if I use the bluetooth functionality, do I need to un-connect from the car via bluetooth first, or can one be connected to both the car and throttle controller at the same time without having to switch between the two?
Android phone, FYI, and a Google search seems to confirm you can connect to multiple bluetooth devices at the same time, but just wanted to confirm. Thanks!
Old Feb 10, 2024 | 10:52 AM
tadda's Avatar
tadda
Veteran: Marine Corps
Not a problem...I use both Android Auto and the Soler App via Bluetooth connected at the same time...
Old Feb 10, 2024 | 01:27 PM
Kracka's Avatar
Kracka
Google Pixel 7 Pro (Android) here, and my Bluetooth will connect with the car, radar detector, and Soler controller all at the same time.
Old Feb 10, 2024 | 03:20 PM
SMOKN C8's Avatar
SMOKN C8
You will not have to disconnect from anything
Old Feb 10, 2024 | 03:30 PM
Red Mist Rulz's Avatar
Red Mist Rulz
What they said. Also, the phone app only needs to connect to the controller when you're changing a setting. In normal use it doesn't connect at all.
Old Feb 11, 2024 | 12:54 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
The Soler throttle controller in not really part of the car as far as your Bluetooth is concerned - it's simply another device. As long as you haven't exceeded the total number of devices your phone lets you connect to it won't be a problem.
To Question on Soler Throttle Controller Bluetooth Functionality
