Engine vents
DFA
https://c8drybayventblocks.com/order...ks-storage-bag
If u want I darkened the fiber glass in the engine compartment then ceramic coated
Wash your car
Open engine bay hatch and remove blanket when done. Wipe up any residual water spots and go enjoy the day.
Wash your car
I bought this for $7, removeable and doesn't leave sticky residue and able to reuse few times.
________________________________________
Currently own:
2019 Mustang GT Premium 6MT Daily Driver
2023 Corvette Stingray 2LT
2017 Porsche 718 Cayman
2009 Jeep Wrangler Rubicon
I find in runs down to the front of the car, under the window etc.. Easily picked up with the corner a large towel. Then I wipe the dust and dirt that comes in thru the fender scoops every time you drive. Then use the dry part of the towel to wipe up all dust on flat panels, engine cover etc.
I wash the C8 as I did my other 5 prior FE Vettes and as I will my 7th an E-Ray (sitting at 4000 in BG lot!) I use a hose powered soaper (nope, don't use my air compressor.) I rinse as I always did with a gentle flow from top to bottom. Then dry. At that point open rear Hatch and deal with the small amount of water.
When I first got my 2020 there were hard to get off water sports. Don't hear much about that now and as were guessed it was probably the thousands of gallons GM uses to check each C8 for leaks. Perhaps they now treat the no doubt recycled water better that they did initially. I used two Meguires products to eliminate those as delivered spots: Water Sport Removal AND Ultimate Black. Never needed Water Sport Removed again. Only used the Ultimate Black after the 1st time a few additional times in 3 1/2 years. Then only on the flat surfaces in the engine compartment.
BTW, mine is a daily driver.
