I need assistance with my passenger-side catalytic converter bolt.
While replacing the exhaust last night, I noticed the bottom bolt is bent and the thread is damaged. My concern is whether the bolt is removable. I don't have much clearance to see from behind, but I did notice that a 5 or 6-mm socket might fit at the front. I haven't attempted to remove it yet because I'm worried about breaking the bolt.
Does anyone have any suggestions or advice? I have attached some images for reference, Thank you.
When I removed my stock exhaust, my exhaust studs on the driver side came out together with the nuts. I would assumed it is the same for the passenger side, meaning you can unscrew that stud out, but definitely use alot of BP Blaster.
