Sponsored by: Wheel Design
Jacking Pucks
Old Mar 18, 2024 | 04:53 PM
EC145Pilot's Avatar
EC145Pilot
Default Jacking Pucks
I have the red jacking pucks that some are using to lift the cars. Liked them but always thought they weren't large enough, in height not in diameter, and always wanted some more space between the jack and quick jack.
I got some new ones from one of our supporting vendors, Elite Engineering. They are the non-permanent type.
They are 1 inch thick, 2 1/2 inch in diameter, aluminum and have grooves to help with grip.
They provide additional space to get between the quick jack and the body to clean, add mods, etc...
Just giving a shout out to a good product.
Old Mar 18, 2024 | 05:04 PM
Maxie2U's Avatar
Maxie2U
I really like those because of their 2 1/2 height. Also really like the ridges on the bottom for better gripping. 👍👍
Old Mar 18, 2024 | 05:44 PM
Nice that they offer additional clearance for the jack pad.
Old Mar 18, 2024 | 05:47 PM
EC145Pilot's Avatar
EC145Pilot
Actually, they are just a bit over 1 inch in height, 26 mm.
Old Mar 18, 2024 | 07:43 PM
Maxie2U's Avatar
Maxie2U
I see my error the 2 1/2 measurement in the picture was in MM.. Still better than those permanent mounted ones that are only 1/2” in height.
Old Mar 18, 2024 | 07:56 PM
Walt White Coupe's Avatar
Walt White Coupe
How about only a little over 1/2 inch thick and less than $30.
Amazon.com: XunDong Corvette Jack Pucks Aluminum Lifting Puck Pad Compatible with Porsche Corvette C7 C6 C5 C8 Z06 1997-2023 (Pack of 4) (Red) : Automotive Amazon.com: XunDong Corvette Jack Pucks Aluminum Lifting Puck Pad Compatible with Porsche Corvette C7 C6 C5 C8 Z06 1997-2023 (Pack of 4) (Red) : Automotive
Old Mar 18, 2024 | 08:42 PM
Greg00Coupe's Avatar
Greg00Coupe
OP Just my perspective.... when I see your jack on a floor with ridges and the potential for the jack to get hung up.... think about these plates I use everytime I use a floor jack. Got them from a metal fab shop. Got to make sure the jack rolls freely as you lift the car.
Old Mar 18, 2024 | 08:55 PM
1 STING's Avatar
1 STING
...Just giving a shout out to a good product.
The permanent pucks work well for me but decided to also have the non-permanent stored in the car just in case.
George
Old Mar 19, 2024 | 07:10 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
I like the notches in those.
Old Mar 19, 2024 | 11:53 AM
EC145Pilot's Avatar
EC145Pilot
Not sure what ""ridges" you are referring to. The jack has never hung up on any of the expansion joints, with the size wheels it has. I place it away from the expansion joints and it only rolls an inch or two when lifting the car. I only lift it high enough to remove a wheel, anything higher and I use the quick jack.
Old Mar 19, 2024 | 02:13 PM
Greg00Coupe
Talking about the expansion joints. You get a stone or anything that hangs up the jack...... it slips.... I'd not take the chance but each to their own. The wheels are wide which don't overcome resistance.
Old Mar 19, 2024 | 03:26 PM
Walt White Coupe
That's the ones I have, but I found I like the non-permanent ones better and carry both when traveling.
And you carry "both" because?
I think the "chamfered" edge on the permanent pucks makes them superior because it helps keep them inside the lifting pad of the jack.
Old Mar 19, 2024 | 04:37 PM
wrecker3's Avatar
wrecker3
I have used these Hockey Pucks starting with my 1989 C4, 2016 C7and now my 2023 C8 with No Problems !!
To Jacking Pucks
