Sponsored by: Wheel Design
Washer fluid help
Old Mar 19, 2024 | 07:58 AM
firenation1254's Avatar
firenation1254
Default Washer fluid help
So typically my car is stored down south but I recently brought it up north, the windshield fluid that I put in a few months ago is rated for +32 degrees however the temperature in my area is gonna get to around 28 in the night. Should I be concerned? I was thinking of maybe getting some all season fluid and throwing it in there to lower the freezing point, would that work?
Old Mar 19, 2024 | 08:05 AM
Mark9's Avatar
Mark9
Put some low temp fluid in and run the washer for a bit to at least attempt to get things mixed in the tank and pump. If it freezes in the lines it probably won't cause an issue and will thaw once warm. If the tank is mostly full, you may want to run the washer to get the tank down to 1/2 way before topping off with the new fluid. I think you'll be ok regardless.
Old Mar 19, 2024 | 08:50 AM
Kracka's Avatar
Kracka
You can pour in a little rubbing alcohol to give it additional freeze protection; alcohol content is what differentiates washer fluid freezing points.
Old Mar 19, 2024 | 08:51 AM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
I say don't worry. If the temp is below 32 this time of year, it is only for a couple hours, not long enough to hard freeze. Adding to whatever is already in the storage tank is a plus!
Last edited by Ron_Attleboro_MA; Mar 19, 2024 at 08:52 AM. Reason: not needed anymore, others have good solutions
Old Mar 19, 2024 | 04:53 PM
gdb069's Avatar
gdb069
Home Depot has Rain-X washer fluid for $4
128 fl oz good for -25 F so add some of that.
Old Mar 19, 2024 | 08:38 PM
Kracka's Avatar
Kracka
Not all regions of the country get the same formula of orange Rain-X washer fluid so freezing point will vary.
Old Mar 19, 2024 | 10:01 PM
jthornton's Avatar
jthornton
I use the GM washer fluid and mix it for winter, no point in buying water.
JT
Old Mar 19, 2024 | 11:37 PM
I guess throwing in some all season fluid would work, but I agree with post 4 - probably not going to get cold enough for long enough this time of year to cause any problems.
To Washer fluid help
