Sponsored by: Wheel Design
Perfomance Exhaust
Old Mar 24, 2024 | 10:12 AM
vipermark15's Avatar
vipermark15
Navigator
Default Perfomance Exhaust
I finally found a 2020 C8 out in Houston. Thanks for all input on buying one with replaced tranny. Question on exhaust. Is there any setting to put the exhaust in track, which I am assuming is wide open, all the time without going thru all those driving modes?
Old Mar 24, 2024 | 10:13 AM
GolferC8's Avatar
GolferC8
You can either customize your My Mode or your Z-Mode. My mode will stay on unless changed, or you can hit the Z button every time you start the car.
Old Mar 24, 2024 | 10:51 AM
vipermark15
Navigator
Thanks for quick response. Will try that later this afternoon. My first trip out exhaust seemed really quite. Thanks again
Old Mar 24, 2024 | 01:29 PM
neogenesis's Avatar
neogenesis
Even in track, the exhaust is never fully open all the time. Due to regulations, even the track setting closes the valves at low RPM, low load scenarios.
Old Mar 24, 2024 | 08:37 PM
Rocketmanwpb's Avatar
Rocketmanwpb
I operate in My Mode with the exhaust set to track at all times 😁
Old Mar 25, 2024 | 08:48 AM
Fishfryer527's Avatar
Fishfryer527
The exhaust is really quiet from inside the car no matter the mode. If you are outside and behind it, it sounds good.
To Perfomance Exhaust
