Proper Tire Pressure C8
Anyway, on page 173 of the manual, it does clearly direct the reader to the door sticker, explains where to find it, and what will be found on it. It is the "cold" inflation pressure for street use. Cold means that it is set at the ambient air temperature. That is, the manual does not indicated any need to adjust the "cold" setting for temperature for street use. If the ambient temperature is 40 degrees F, set it to 30 psi. If the ambient temperature is 90 degrees, set it 30 psi. I get it that some will adjust this a bit to compensate for changes in ambient temperature throughout the day - I usually don't worry about that. I think there is a good bit of tolerance in the acceptable psi range for a fully warmed up tire in street use. And yes, if there is a significant change in ambient temperature - yes it needs to be adjusted when the tires are cold. I find that when I set the pressure in the Summer months, and then we have significant drop in temperature, the cold pressure drops enough to trigger a low tire pressure warning while sitting in my garage.
It used to be the tire manufactures recommended the cold pressure was defined to be 68F, which is the standard temp (STP). It got too complicated for the lay and they changed to just cold temp. It is totally acceptable to set the pressure at a nominal value. Using this method will usually half the change in pressure variation. Now if you want use ambient regardless of the extreme you should check your tire inflation every time you drive or every time there is substantial change in the ambient temp. This might include after every static interval which would be another argument of how long, 4hrs, 8hrs overnight etc.
It is hard enough to convince most people to check their tire pressure let alone make it more complicated. The best rule of thumb is to check it during a nominal daily ambient temperature. This would not be in the morning before you drive if it is very cold out. Rather check it when the tire is cold or acclimated to the ambient temperature during the average of the day.
How to Check
Use a good quality pocket-type
gauge to check the tire
pressure. Proper tire inflation
cannot be determined by looking
at the tire. Check the tire
inflation pressure when the tires
are cold, meaning the vehicle
has not been driven for at least
three hours or no more than
1.6 km (1 mi).
Remove the valve cap from the
tire valve stem. Press the tire
gauge firmly onto the valve to
get the pressure measurement.
If the cold tire inflation pressure
matches the recommended
pressure on the Tire and
Loading Information label, no
further adjustment is necessary.
If the inflation pressure is low,
add air until the recommended
pressure is reached. If the
inflation pressure in high, press
on the metal stem in the center
of the tire valve to release air.
Re-check the tire pressure with
the tire gauge.
Put the valve caps back on the
valve stems to keep out dirt and
moisture and prevent leaks. Use
only valve caps designed for the
vehicle by GM. TPMS sensors
could be damaged and would
not be covered by the vehicle
warranty.
There is no mention of adjusting cold inflation pressure to compensate for when the ambient temperature deviates from standard temperature. I have never seen a car or tire manufacturer recommend compensating cold inflation pressure for street driving when ambient temperatures deviate from standard temperature. Do you have a source from a car or tire manufacturer that recommends compensating for ambient temperature when inflating cold tires?
Keeping this in mind, you have to fill at 104 degr F /40 degr C ambiënt temperature, a higher cold pressure then at 68 degr F /20 degr C.
This because cooling down is also worse at 104 degr F ambiënt.
The lesser deflection the higher pressure gives, gives then lesser heatproduction at same speed. So heating up and cooling down of tire-material stays in line so tire-material still wont reach 120 degr C/248 degr F.
A man from Nokian (norwegian tirebrand) wrote me that that is the critical temperature, at wich tire-material hardens and little cracks are made, wich tear further in time, until, mayby after 2 years that far that tire blows or treath seperates, and then other factors are blamed.
So this overheating is only allowed "ZERO" times in tires use.
General idea is to fill determined best pressure at ambiënt temperature, be it 20 or 110 degr F.
But I dont agree with that, and in about 20 years I will be proven right.
So I am in the camp of calculating cold measured pressure back to an index temperature, as Rimex calls it, a company for earthmovers tires.
They use 20 degr C/68 degr F as index temperature, but I have read 65, 68, 70 degr F.
Can give you text I wrote about it for an RV forum, using 80 psi cold pressure as example, but it goes for lower pressures the same.
So opinions are devided about this.
That people with autority write things, dont always mean they are right.
The earth proved to be not flat.
Made a list using index temperature 70 degr F/21 degr C.
In that search your determined cold pressure, and it gives howmany degr F change per 1 psi change.
70degrF./degrF/psi
20 psi/ 15,5F/psi
21 psi/ 15F/psi
22 psi/ 14,5F/psi
23 psi/ 14 F/psi
24 psi/ 13,5F/psi
25 psi/ 13,5F/psi
26 psi/ 13 F/psi
27 psi/ 12,5 F/psi
28 psi/ 12,5 F/psi
29 psi/ 12 F/psi
30 psi/ 12 F/psi
3 1psi/ 11,5 F/psi
32 psi/ 11,5 F/psi
33 psi/ 11 F/psi
34 psi/ 11 F/psi
35 psi/ 10,5 F/psi
36 psi/ 10,5 F/psi
37 psi/ 10 F/psi
39 psi/ 10 F/ps
40 psi/ 9,5 F/psi
42 psi/ 9,5 F/psi
43 psi/ 9 F/psi
45 psi/ 9 F/psi
46 psi/ 8,5 F/psi
49 psi/ 8,5 F/psi
50 psi/ 8 F/psi
53 psi/ 8 F/psi
54 psi/ 7,5 F/psi
58 psi/ 7,5 F/psi
59 psi/ 7 F/psi
63 psi/ 7 F/psi
64 psi/ 6,5 F/psi
70 psi/ 6,5 F/psi
71 psi/ 6 F/psi
77 psi/ 6 F/psi
78 psi/ 5,5 F/psi
86 psi/ 5,5 F/psi
87 psi/ 5 F/psi
96 psi/ 5 F/psi
97 psi/ 4,5 F/psi
109 psi/ 4,5 F/psi
110 psi/ 4 F/psi
126 psi/ 4 F/psi
127 psi/ 3,5 F/psi
148 psi/ 3,5 F/psi
149 psi/ 3 F/psi
177 psi/ 3 F/psi
How to Check
1.6 km (1 mi).
the tire gauge.
warranty.
However, I did find a source that discusses a reference temperature of 68 degrees.
https://www.rimex.com/wp-content/upl...n-pressure.pdf
If it was appropriate for this application, and you were setting the tire pressure at 40 degrees, but wanted it to result in 30 psi when the tire gets to 68 degree, then you would set the pressure low, by about 2.32 psi, to 27.67+/-. Yeah - i wont be doing that. But I don't that this particular source is applicable anyway. It is by RIMEX and the context appears to be for extreme heavy equipment. RIMEX is an international company that manufactures TyreSense which is "a tire (tyre) Temperature and Pressure Monitoring System (TPMS) designed for mining and industrial operations of all sizes from single operator-driven vehicles to large autonomous fleets." They also appear to make heavy duty wheels for those applications as well.
Bottom line is I believe that the intent is to set the cold tire pressure at ambient temperature and it will result in an acceptable warm/hot tire pressure in street use.
The next three are the Owners Manual, Tiregrade, and Michelin statements:
Once filled to this system, you can let the cold pressure flow with ambiënt temperature, and not maniacally let of and fill up when large temperature swings.
And the list I gave, can be used to calculate by head accurate enaugh for the goal.
Yust for checking, so you dont worry.
That Rimex pdf comfirms my idea, and is also an autority to my opinion.
But even autority's in the field can make mistakes.
RIMEX uses absolute pressure in their example, and not gauge-pressure wich is 14.7 psi/1.013 bar lower then absolute pressure.
Their example is high pressure, so ambiënt pressure is relatively small part, so error is marginal.
But when used for 29.4 psi gauge-pressure the ambiënt is 1/3th of absolute pressure, and error gets serious.
I wrote Rimex about this, but conversation mostly goes into the twilight zone.
I made a temperature/tirepressure calculator myself.
A spreadsheet that calculates pressure change for temperature in tire change, and the other way around. For absolutely dry gascompound in tire, like Nitrogen lobby claims, but also for if enaugh water in tire, and I think I am first in that.
If you mail me at my hotmail. com adress with username jadatis, I can send it in return.
Like this cripted so spamm machines cant figure it out, so combine yourselfes.
Now cars often have tmps, people worry more about pressure swing. And using the calculations can ease their minds.
After a while you understand the system, and dont calculate or worry anymore.
"The cold inflation pressure is the contained air pressure of a tire that would occur at an indexed temperature,
usually 20°C or 68°F. This indexed temperature is based on the ideal ambient operating conditions for
the tire. There is ambiguity in the definition of cold inflation pressure among tire manufacturers. Some
manufacturers index cold inflation pressure to 18°C or 25°C, or have another definition altogether."
https://www.corvetteforum.com/forums...post1607685666
Since each manufacturer sets it, how does Michelin say to set cold tire pressure for their passenger car tires? Like this:
"For best results, check your tire pressure when tires are cool– before driving the car or if it has covered less than 3 miles at low speed. If the tire is hot, add 4-5 psi to the car manufacturer's recommended pressure value (0.3 bar) or wait until it has cooled down, which is an average of three hours after parking the car." No mention of a reference pressure or any need to make special adjustments.
https://www.michelinman.com/auto/aut...tire-care-tips
What could be simpler than just checking/setting the tire pressure before you drive the car to the psi on the door pillar at whatever the ambient temperature happens to be? Its what I do, and give it no further thought. The available tire temp display tile is useful for track use, but to me its just a novelty for street use.
