Short Quick Jack Notice
When NOT in use, I store mine flat on the floor under our daily driver. If you look closely, or zoom in, you can see that I store the power unit, on the left side, under the side of my roll away tool chest. Fits under there perfectly. I coil up the hydraulic hoses and they hang on the other side of the tool chest.
With the Swiss Trax flooring, the Quick Jack slides around easily. It also works extremely well for having reference points to make sure that I have the two QJ rails parallel to each other, and aligned front to back equally too.
Before I bought my flooring I was chatting with a guy in Mass who said once a year at the end of the snow issues, he would just pull up a large section of his floor and drag it out in the driveway and hose it off, including his bare concrete floor that is under the Swiss Trax.
I looked into the interlocking floor tiles, but the maintenance was a concern for me, not to mention the cost. I was able to get my full broadcast Polyaspartic epoxy floor done professionally for nearly half what the cost would be with tiles. And no maintenance at all... I blow the dust and leaves out sometimes, hose it down and mop it once a year or so. With tiles, all that dirt and dust and drips just goes under the tile, it's still there. Not to mention if you spill oil or something else messy. You can still get stains too if you don't coat the concrete. Everything slides around easily on my epoxy too, and I could get all kinds of custom colors if I wanted. For me it was an easy decision to go with the epoxy.
As for maintenance, I use my shop vac once or twice a year to vacuum up what sand, and other particles, bugs etc come up through the tiles and it's all good. Only a couple times in 5 years have I taken a wet rag to wipe up spots, or salt mess after the snow season.
It's not slippery when wet either.
My garage is an oversized 2-car, it’s about 650 sf including the storage area. Floor tiles are $5, so that’s $3250 in tiles. Plus I needed extra for overage for the cuts and angles. I also wanted the finished edges, and my storage area is raised a step up. So there’s a few hundred more for edging, tax, etc. And I like I said above, I still wanted to protect the concrete under the tiles, so at least some floor paint was needed. It was close to $4k all in. And then I was going to spend a weekend sitting on the floor planning it all out, trimming around corners and steps, etc. honestly it probably would have taken me more than one weekend too, so that’s 10 days with no garage.
Then I started shopping for epoxy. The “cheap” epoxy from the builder’s contractor was only $1000, for the whole garage. No flakes, just grey epoxy with a clear coat. I almost went for it because it’s just a bargain. But I happened to also go to my detailer that same week and he had just had his floors done with the full broadcast epoxy, the extra thick kind, it looked amazing. He put me in touch with his guy and I got the deal he was offering to all the employees at the detail shop… $2k for a two car garage. He didn’t care that I had the storage area to the side but if he had charged me the regular rate I would have been in for $2600. Now that’s all in, no work besides emptying the garage. No edges, no gaps, no worries over angles or cutouts. The step up to the storage is completely covered no visible tile edge. It’s also not slippery when wet, he applies an anti skid additive that works great. Now it’s true that I could have paid more for even thicker coatings or custom colors or just more expensive contractors but the highest price I was quoted didn’t come close to double the price of the floor tiles. I think it was $4500 from Gorilla Garage. The typical price is $800-1200 per stall.
I don’t doubt that the maintenance on the garage tiles is easy, but it’s even easier with epoxy. And I can’t get past that issue of spilled oil. One mistake on tiles is just a hassle to clean up. For me it was just tossing some cat litter on it and sweeping it up.
If I didn’t do epoxy I would have done either commercial porcelain tile or commercial VCT tile. Both options are about $2/sf for materials. If you can install your own tile that’s a big savings, or I can pay $2/sf to have it installed. Still cheaper then snap fit tile and much nicer. The VCT tile is an easy DIY install, but it needs some kind of top coat. Either you have to wax it regularly, or you need to apply a clear epoxy over it. Same epoxy clear coat as I got on my floor, but it’s an easy DIY too since there isn’t really any prep. It just goes on over the VCT tile. So add $500 for epoxy or maybe $1000 if you have someone do the clear coat for you. Again… still cheaper than snap fit and a more permanent installation.
