Outside air temp. sensor
Got an A/CDelco sensor coming tomorrow . $10 from Amazon.
The problem I was having is that it took anywhere from 20-30 mins. before it started to change the display to the current outside temp. and even then, sometimes it wasn't accurate. If this doesn't fix the issue I'll have to take it to the dealer.
68/70Vette - In it's position, the sensor isn't affected by anything other than the air coming through the grill as the belly pans protects it from any other outside influences.
Thanks again Andy. No way I would ever have found it if you hadn't given me a starting place to look.
The engine compartment cooling fan system is composed of two electric cooling fan motor and control module assemblies. The integral motor and
module is a solid-state device with a driver capable of handling the high current demands of the fan motor. The under-hood air temperature sensor
is an input to the fuel pump driver control module. The engine control module (ECM) and fuel pump driver control module communicate via serial
data. The ECM uses the under-hood air temperature sensor to determine the desired engine compartment fan speed which in turn is communicated
to the fuel pump driver control module. The fuel pump driver control module controls the fan speed by sending a pulse width modulated (PWM)
signal to the engine compartment cooling fan control module. The engine compartment cooling fan control module varies the voltage drop across
the cooling fan motor in relation to the pulse width modulated signal, allowing the cooling fan to operate at variable speeds."
It is difficult to find in the Service Manual, because its not named consistently. Its called the underhood air temperature sensor in the descriptive text. But the replacement for it is called
"Ambient Air Temperature Gauge Sensor Replacement (Engine Compartment Air Temperature)". And notice that it mentions "Gauge" in the name, just like it does for the one found in front. The "Engine Compartment Air Temperature) and its location in the illustration makes clear (I think) that this is the one that would be used for the rear cooling fans. If there is yet another one, I can't find it. There are other temperature sensors for different purposes, and I think they may be all the same. The manual is 7000 pages with no index, so you never know.
Soooo, under the passenger's air deflector?
