In case I'm using the wrong term, its when you push both paddles, release one of them, and then press them both again. The gear indicator goes blinky blue and you get the green cog indicator.
I'm assuming that when you activate this mode that the car is essentially in neutral at that point. I ask because the launch mode has you depress the brake first. In manual mode, my brain trying to do three things at once: hold the accelerator, hold the brake, hold the shifters. Then I let go of two of those three to make the car launch. Or does the brake automatically engage in manual launch mode and all you worry about is accelerator and paddles?
Originally Posted by RandelB
The following is from a 2022 owners manual.
Yes. But he is talking about Manual Launch Mode which is new for 2024. His question is about the role of the foot brake in manual launch, and if the car already applies the brakes (I doubt it). The explanation for double paddle declutching, normal, rapid exit, and now manual launch say nothing about the foot brake. I think some experimentation will answer the question.
I thought in "launch mode" you entered that mode, pressed brake and accelerator. The engine revved to the selected rpm & tire slippage (on 2024) and you just released the brake and held on and enjoyed the shifts. No paddle needed.
As I remember the "gear" icon means you've entered performance shift mode on my 2020, perhaps that is a way to force performance shift mode?
Edit: Never mind, I just caught the details of the manual launch mode in @Andybump 's post.
Again, he said manual launch mode which is new for 2024 and is initiated from a double paddle declutch. Its only described in the 2024 manual. I posted it above.
Sounds like it. It does not say the brake must be held so I think you can just rev up the engine and release the pedal. Hold the brake if needed or wanted., I suppose.
Thanks for the clarification Andybump. I did not realize there was another version of launch control. I have a 24 but have not gotten there yet, as far as launching it.
Yeah, I was thinking the same. Wasn't able to go back and try again. My hunch is that the brake does not engage unless you hold the pedal down. But then again, it's all electronic so...
Confirmed, it puts you in neutral. So the trick is to release the brake and paddles while nailing the throttle. I'm sure with practice it will come to me but it's not very natural for me. Sort of tough to heel/toe in these cars so it's two feet driving. Unnatural I say.
