Sponsored by: Wheel Design
Transmission issue
Old Apr 27, 2024 | 07:37 PM
mavallone997's Avatar
mavallone997
Default Transmission issue
Fellas, been loving my c8 since november its been new to me- 5k miles total 2020. I upshifted felt the car slip into neutral- it moved in 2nd gear then shift up same thing- car was stuck in neutral-
“service transmission/ idle creep messages”on my cluster with a abs light on.
Had to get towed home- plugged in my autel scan tool and saw many faults saying odd gear faults- with a quick reset the car started moving again
but many odd communication codes and abs lights stood-
Is gm aware of this? Is this covered on my end?
Popular Reply
Apr 27, 2024, 07:46 PM
RKCRLR's Avatar
RKCRLR
Powertrain warranty is 5 years so DCT problems should be covered. However if you erased the DCT codes then they may not cover it until they come back.
Old Apr 27, 2024 | 07:38 PM
spearfish25's Avatar
spearfish25
Just take it to your dealer bro.
Old Apr 27, 2024 | 07:39 PM
mavallone997
broo is this under warranty? Gm says 3
Years/ 36k mi
Car is a 2020
Old Apr 27, 2024 | 07:46 PM
RKCRLR's Avatar
RKCRLR
Old Apr 28, 2024 | 07:03 AM
Ystayhm's Avatar
Ystayhm
When something like that occurs have OnStar run a diagnostic report so you have a record for the dealer
Old Apr 28, 2024 | 07:38 AM
JABCAT's Avatar
JABCAT
Probably should read up on the C8 DCT issues, ongoing since 2020. Good luck.
Old Apr 28, 2024 | 09:29 AM
sowega's Avatar
sowega
they’re aware, it’s covered by the warranty, and the only thing you have to worry about is that the parts aren’t always available - I waited 5 weeks for a new valve body when my 22 had the same issues. Get it to a dealer asap so they can diagnose and order parts sooner rather than later (if needed)
Old Apr 28, 2024 | 12:12 PM
Recommend you take it to your dealer and let them do a diagnostic review to see what is going on.
To Transmission issue
