Sponsored by: Wheel Design
Squeaking…
Old May 17, 2024 | 10:08 PM
vexeddonut's Avatar
vexeddonut
Cruising
Default Squeaking…
I bought my C8 brand new a couple of months ago and now it’s making these weird squeaking noises from behind, what could it possibly be??? Anyone else experience this???
Can be heard @ 0:14, 0:16, 0:21, and 0:49
File Type: mp3
Old May 17, 2024 | 10:56 PM
sTz's Avatar
sTz
All I hear in the clip is the exhaust and tire/road noise. Perhaps you’re hearing the injectors, which sounds like a sewing machine…
Old May 18, 2024 | 12:04 AM
Avanti's Avatar
Avanti
I've seen a number of later Vettes' seat springs squeak once in a while.
Old May 18, 2024 | 05:34 AM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
Need a better audio file. No cars passing, windows closed?
I did hear squeak. Maybe chirp, like a bird.
Old May 18, 2024 | 03:20 PM
INTIMIDAT3R's Avatar
INTIMIDAT3R
My C7 had the same issue right off the truck. Drove me and the service tech nuts.
Then an old Corvette guy told us to use the silicone lube on all the weather stripping and violá... no more squeaking.
Old May 18, 2024 | 04:44 PM
Andybump's Avatar
Andybump
Coupe or HTC
Old May 18, 2024 | 07:52 PM
TopGunn's Avatar
TopGunn
Mine (HTC) made a hellish squeak that turned out to be the rear window. A little lube on the gasket solved it.
Old May 19, 2024 | 01:08 AM
vexeddonut's Avatar
vexeddonut
Cruising
Turn it up all the way, you kinda have to listen in carefully since it’s coming from outside, it’s a high pitched squeak
Old May 19, 2024 | 01:10 AM
vexeddonut's Avatar
vexeddonut
Cruising
Originally Posted by INTIMIDAT3R
My C7 had the same issue right off the truck. Drive me and the service tech nuts.
Hmm… I wonder if it’s the same for the C8…
Sounds like an easy fix
Old May 19, 2024 | 01:11 AM
vexeddonut's Avatar
vexeddonut
Cruising
Originally Posted by Andybump
Coupe or HTC
Coupe!
Old May 19, 2024 | 05:43 AM
Ron_Attleboro_MA
Any silicone lube on the rubber gaskets. (Doors, remove top, rear truck hatch)
Call me crazy but I have been using WD40 on my fan belts for 40 years. You can spray it on not running so it doesn't get blown all over.
Is the noise tied to the engine rpm or is it related to motion, bumps?
​​​​​​​Good luck.
Old May 19, 2024 | 08:34 AM
Andybump's Avatar
Andybump
I heard the squeak at the times indicated. Does not sound so much like the weatherstip squeak. What it does sound like is the occasional squeak my muffler cylinder deactivation exhaust flow control valves make when they transition between V4 and V8 mode. And also, with NPP, the tailpipe flow control valves will open and close depending on the Driver Mode and throttle demand. In Tour they are closed at idle an benign driving but twill open with spirited driving. With Sport the are open at idle and most driving scenarios. With Track they open nearly all the time. But even in Sport of Track, they will close at times to meet Federal Bypass Standard. The point is, those valves can open and close during normal driving, and if they squeak, which mine do from time to time. you can hear it.
I think you can test it (if you have NPP) Just sit in the driveway with the engine running and idling. Switch the drive mode between Tour and Sport. See if you hear the valves move or squeak. If you dont have NPP, the other AFM valves in the muffler could be the ones that squeak.
Old May 19, 2024 | 11:50 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
In fact as part of ongoing maintenance it is recommended to use a silicon based gasket lube......been the same on Vettes for generations.
Old May 20, 2024 | 02:27 AM
vexeddonut's Avatar
vexeddonut
Cruising
​​​​​​​Good luck.
Think it's just motion, rpm doesn't really affect it.
Old May 20, 2024 | 02:31 AM
vexeddonut's Avatar
vexeddonut
Cruising
I'll test this theory out tomorrow, but I doubt this is what it is since the exhaust's always in track and it happens way too often.
Old May 20, 2024 | 08:17 AM
Andybump's Avatar
Andybump
Understood.
Old May 20, 2024 | 12:53 PM
lgodom's Avatar
lgodom
I'd try a set of chassis ears which allow you to place microphones at various locations to isolate the noise. They make wireless and wired models.
Old Oct 21, 2024 | 03:42 PM
SolidNismo's Avatar
SolidNismo
I'm having this exact same issue... Did you ever figure it out?
To Squeaking…
