Sponsored by: Wheel Design
Mouse blocker
Old May 24, 2024 | 02:42 PM
Revmanii's Avatar
Revmanii
Knock on wood, my first winter storage seems to have gone mouse free. I used the Fresh Cab pouches. One in the frunk, one in each footwell, and one in the trunk.
Old May 24, 2024 | 04:14 PM
Bluehinder's Avatar
Bluehinder
I'm a licensed pesticide applicator, the the best solution by far is rolled oats coated with zinc phosphide. Brand name is Prozap. Sprinkle a few under the car. One bite of one oat and they dead in seconds. They make it few inches.
The active ingredient is converted to phosphine gas when it interacts with stomach acid. It dissipates from the body and is then harmless to other animals.
Old May 24, 2024 | 08:49 PM
2022Yellow's Avatar
2022Yellow
Irish
Spring soap and carve with a knife, and also the rodent units you plug into to the wall help a lot
Old May 24, 2024 | 10:07 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Originally Posted by 2022Yellow
Irish
Irish Spring doesn't work.
Old May 24, 2024 | 10:33 PM
db4375's Avatar
db4375
Where can it be purchased?
Old May 24, 2024 | 11:24 PM
Originally Posted by F4Gary
Doesn't work. They will make a nest out of that stuff.
I've used Bounce dryer sheets for years and have never had a rodent problem in the garage or car. But this thread is interesting in that new ideas for keeping the critters out has been mentioned.
Old May 24, 2024 | 11:38 PM
wdwinder's Avatar
wdwinder
St. Jude Donor '24
Originally Posted by SCorvette08
Does anybody use the mouse blocker? I was thinking about buying one do they work?
Mouseblocker.com
Kind of like proving a negative, but, I did put one on my Tundra a few months ago after trying the sprays after they ate my knock sensor harness. Have not had any evidence of them returning since. It was pretty frequent before that. So I think they work. Hardwired into the battery.
this one.......
https://www.amazon.com/gp/product/B01MG94UER/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01MG94UER/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Old May 25, 2024 | 06:43 PM
F4Gary's Avatar
F4Gary
That stuff sounds nasty. Wouldn't want to mishandle it.
Old Jun 11, 2024 | 01:29 PM
Revmanii's Avatar
Revmanii
this one.......
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Yeah, did my efforts keep them out or was there just no mice threat to fend off this year? When it comes to critters, I've found my best defense is a good, and full time offense.
Old Jun 11, 2024 | 02:33 PM
papillion's Avatar
papillion
Default Prove a negative?
I keep one of these under a Mazda CX5 that is parked on the drive. Put it in a small crab bait wire cage to make it easy to retrieve and hard to carry off. Both from amazon. 3 AAs lasted just short of 6 months. Beeps blinks red when batteries need to be changed. Does it work? No rats so it either does? Or I didn't need it to begin with. Being proactive made me feel engaged in the fight if nothing else.
Old Aug 18, 2024 | 08:22 PM
Hib Halverson's Avatar
Hib Halverson
Pro Mechanic
Pro Mechanic
When I search for "Prozap" the product that comes up are "strips" you hang in places where you want to kill flying insects.
Are you sure you have the brand name correct?
When I searched for "rolled oats coated with zinc phosphide" the top search result was for a product called "ZP Rodent Oat Bait" made by "Bell Laboratories".
Old Aug 19, 2024 | 09:36 AM
Andybump's Avatar
Andybump
Default is this the stuff?
Old Aug 20, 2024 | 12:27 AM
  #33
Rollochrome's Avatar
Rollochrome
I put the plastic traps that are like little hotels out about the size of a large shoe box
Inside you put some sort of green candy bar with vitamin k or something like that in it and the mice get poisoned or have renal failure from K overdose ?
Sort of the same thing as the commercial ones you see at buildings in public
I put out like 20 of these around outside
Got them in the flowerbeds. Got them everywhere
Significantly knocked the darn mouse population down and have not seen them around the house since
They made a brand new $90k F-450 smell like mouse pee on start up and I was beside myself about it so I spent the cash to go to war on them and am kicking myself for not committing rodent genocide any sooner
EDIT TO ADD: Also, since I removed their primary food source, I have not seen a single snake this summer either, and I am usually seeing a fair share of copperheads, rattlers, and king snakes all summer. SO I am changing the ecosystem apparently
Old Aug 20, 2024 | 08:14 AM
  #34
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
Which Prozap are you using? They have several different versions. I'm guessing the one for moles?
Old Oct 30, 2024 | 07:01 PM
  #35
kenmo's Avatar
kenmo
Originally Posted by Andybump
Can you kindly post a link? Searching on Amazon does not find the product in the image. Thanks kindly...
Old Oct 30, 2024 | 07:52 PM
  #36
Avanti's Avatar
Avanti
Never heard of this. I keep reasonably fresh mouse killer from Walmart or Lowes in all my "out" buildings, including my large garage without issue.
Old Oct 30, 2024 | 11:02 PM
  #37
shiumai's Avatar
shiumai
Modified C8 of the Year 2021 Winner
Earlier this month I opened my garage door only to catch a glimpse of a smallish roof rat scurrying under my C8. I set out some mouse traps with peanut butter and in the morning one of them had trapped and killed it. I prefer to set traps where I can dispose of the dead animal instead of them dying somewhere I can't reach.
Old Nov 1, 2024 | 08:52 PM
  #38
Walter Raulerson's Avatar
Walter Raulerson
Peppermint
Old Nov 1, 2024 | 09:42 PM
  #39
pltmgr's Avatar
pltmgr
Outdoor cats. Had an outbuilding infested with mice, rats, squirrels. Destroyed the insulation, chewed soffit and fascia, even chewed electrical wiring, and I won't mention the urinary and fecal waste. Tried a number of things but nothing worked saw well as outdoor cats. Another benefit- less snakes.
