Sponsored by: Wheel Design
Trickle charger
Old Jun 20, 2024 | 04:37 AM
Bethelvis's Avatar
Bethelvis
5th Gear
Default Trickle charger
Newbie here
2020 vette 2LT
what conditions warrant a trickle battery charger?
Popular Reply
Jun 20, 2024, 05:36 AM
449er's Avatar
449er
CF Community Team
My suggestion would be to use a battery tender anytime the car will sit for a week or more
Old Jun 20, 2024 | 05:36 AM
449er's Avatar
449er
CF Community Team
Old Jun 20, 2024 | 05:49 AM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
Same!
Avoid problems. You might stretch to anytime longer than 2 weeks.
Also check when updates are allowed on your car. If done without permission, you definitely want a maintainer on the car.
Enjoy.
Best wishes to all.
Old Jun 20, 2024 | 07:54 AM
johnodrake's Avatar
johnodrake
Moderator
I have, for many years now kept my Corvettes on a maintainer when it is in the garage. Now I do it on all my vehicles to prevent low charge levels on all our vehicles. This becomes important if your norm is multiple short trips which will not allow the vehicle battery to fully recharge. From experience!
Old Jun 20, 2024 | 08:11 AM
Mrchen's Avatar
Mrchen
I have the car plugged in every night its parked, neve rknow when a big update will hit and drain the battery
Old Jun 20, 2024 | 09:06 AM
BasicMember's Avatar
BasicMember
I like to plug in the Battery Tender every couple of weeks for a few hours but don't leave it on permanently.
Old Jun 20, 2024 | 09:17 AM
Waterline's Avatar
Waterline
I never store the car without having a battery maintainer plugged in. IMO GM batteries are pretty much junk and don't last more than 2 or 3 years. However, my C6 was always plugged in and I sold it after 7 years with the original battery. Go figure. I have maintainer plugged in everything I own with a battery. Boat, tractor, riding mower, generator and my Jeep CJ7, but not my daily driver.
Old Jun 20, 2024 | 09:25 AM
BasicMember
I have a Delco battery going on 8 years old. Just put to rest, bless it's soul, a 15 year old garden battery.
Old Jun 20, 2024 | 09:45 AM
Glen e's Avatar
Glen e
i’m not so much worried about batteries that are relatively new, meaning less than two years, When a do a quarterly test for battery drain and see that it’s negligible, I don’t use a maintainer. But once I get to about two years, I start suspecting the battery. , down here in Florida, we see batteries go bad after three years all the time, on every model out there. AAA does amazing business with batteries here in Florida. There is a AAA truck replacing a battery monthly in my 400 car condo garage.
Old Jun 20, 2024 | 09:49 AM
biketom5's Avatar
biketom5
Same here. I keep a battery tender on my other vehicles too that are not driven often.
Old Jun 20, 2024 | 10:09 AM
Red Mist Rulz's Avatar
Red Mist Rulz
Lots of urban myths regarding the C8 and battery drain. One of our own forum members did a very comprehensive parasitic drain test on the C8 and found out that it is very, very low. Much below GM's standards, and no higher than any other modern car (and probably lower than many). If you don't keep your other cars on a maintainer, there's really no need to do it on the C8. Especially not every single night. If the car's going to sit for an extended period of time, using one will prolong battery life some. As a test, I let my car sit for three weeks while I was out of the country. It started up just the same as if I had driven it the day before.
Old Jun 20, 2024 | 10:23 AM
Glen e's Avatar
Glen e
agreed, I just went five weeks without a start when I was up north visiting relatives. it started perfect when I got home. Think about it, a car can’t really be designed so that it only goes a week or two, otherwise you would have cars with bad batteries littering long-term storage at every major airport in the nation. I’m sure the design spec on every car is that the battery has to last a month if everything is in good shape.
Old Jun 20, 2024 | 10:32 AM
RKCRLR's Avatar
RKCRLR
While I agree with the recommendation to use a maintainer if you often go more than a week without driving (which is consistent with GM's guidelines) I often go more than a week without connecting a maintainer. I plan to drive my car more often but life gets in the way and have gone weeks without driving it. But if I know beforehand that the car is going to sit for weeks at home without being driven I will connect a maintainer.
Old Jun 20, 2024 | 11:08 AM
sprtplt's Avatar
sprtplt
TWO days is enough for these cars to lose significant charge.
Old Jun 20, 2024 | 11:34 AM
24RiptideBlue's Avatar
24RiptideBlue
Originally Posted by Bethelvis
Newbie here
2020 vette 2LT
I plug my car in any time I’m not going to use it the next day. Also if you drive a lot of short trips plugging in the trickle charger overnight helps keep the battery fresh.
Old Jun 20, 2024 | 11:45 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Yep all the silly paranoia is crazy! As you note, Andy Bump measured the paratactic draw of a C8 after it shuts off essentially most power after ~10 minutes. He measured 15 milliamps. Thats less power than your TV in standby waiting for you to turn it on with a remote! Or and LED night light!
Don't believe what it does? Open Frunk, Truck, turn on Interior Map lights. Watch in 5 to 10 minutes and they all go out! Was the same for my two C7s. Was on vacation for 3 weeks with both C7s and my C8. Did not use a charger and started just fine. From table below in GM 2014 Service Manual states it will start an 80% charged battery after >33 days.
All my 7 Vettes have been DD's. Don't need to mess removing or installing a charger when I want to drive. Been retired since 1999, don't have to drive every day BUT still drive a minimum ~3 days a week. Silly to plug it into a charger. If I let it sit for ~week it does take 30 miles to get back to 80% charge (BTW that is all the car will charge it, like most modern cars to reduce energy use!)
Now my street rod that only goes to car shows stays plugged into a maintenance charger 24/7!
Old Jun 20, 2024 | 11:59 AM
BasicMember
Not if your battery is any good.
To Trickle charger
Old Jun 20, 2024 | 12:18 PM
JerryU's Avatar
JerryU
Heck my Corvettes, since two C7, C8 and now my E-Ray are far better than other cars and trucks. Silly to think the Vette is worse as it's equipped with circuits that shut down ALL significant power after ~10 minutes. As I said, test it for yourself and watch!!
They are NOT like my 1st of 7 Vettes, a 1988. With it, leave an interior light on and battery dead in the morning!
Old Jun 20, 2024 | 12:35 PM
johnodrake's Avatar
johnodrake
Moderator
To net it out, It is probably (under most circumstances) not ever going to be an issue. That said, using a maintainer never hurts the battery.
Old Jun 20, 2024 | 12:42 PM
Andybump's Avatar
Andybump
Newbie here
2020 vette 2LT
The getting to know your Corvette says this, about that.
And, my measurement of the parasitic draw appears here:
https://www.corvetteforum.com/forums...e-battery.html
For the record, my battery maintainer is connected whenever the car is parked in the garage. Mainly, its because it is right there and it is easier to do it than to think about it. I could offer technical reasons, but you can see from other responses that practical experience seems to say you can more than a week at least.
