Sponsored by: Wheel Design
Question about tracking a C8
Old Jul 9, 2024 | 04:13 PM
C7Me's Avatar
C7Me
Purveyor of Common Sense
St. Jude Donor '19
Originally Posted by camelhead
I see.
So a Stingray with Z51 is a "track car" while one with out that option is not.
Neither is a "race car" if I am understanding your correction clearly.
Yes, that is correct and pretty clear. A track day car is not a race car, simple. What's your problem with that???
Old Jul 9, 2024 | 04:42 PM
Fast Dawg's Avatar
Fast Dawg
Originally Posted by sshallen
Eh, most drivers would never notice in an A/B test driving legally on a road. I specifically did not want summer only tires limiting four seasons usability. I definitely did not want the brake dust. Because it's already a 1%er in those areas. I did my build with no concern for money, but the factors above nixed Z51. It's good to realize that not EVERYONE thinks exactly the same. I can't for the life of me understand why someone would order a dream car as a coupe when HTC is has no downside (other than not showing the molded engine cover), but not everyone thinks like me!!! If we all thought the same, GM would sell one configuration in whatever they determine is the "best" color. Why would anyone want anything else?
Exactly.
Old Jul 9, 2024 | 05:21 PM
camelhead's Avatar
camelhead
Banned Scam/Spammer
No problem at all my friend.
The track day stuff just needs to be dumbed down a tad for us "waxers".
Old Jul 9, 2024 | 07:25 PM
jthornton's Avatar
jthornton
Henry Ford used to think that way, you can get a Model T in any color you like so long as it's black!
JT
Old Jul 9, 2024 | 07:30 PM
jthornton's Avatar
jthornton
Originally Posted by x86guru
If money was not an issue, why on earth would you want to perform spirited street driving on purpose with less traction, less handling, less braking power, less spirited exhaust sound, less torque, etc. If you just like the looks of the Corvette C8 and not keen on performance attributes, then non-Z51 makes sense possibly.
Money was not an issue for me, and I thought at one point I had to get a Z51 to get the performance exhaust but found out later that was not the case and I was so happy because 99.9% of my driving is relaxing... and with 20k miles in the first year and maybe 40 miles on a track one day I'm a happy guy.
JT
Old Jul 9, 2024 | 08:24 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by jthornton
Track use... Track days... or spirited driving. I did run my non Z51 on a track for 10 minutes or so per hour for a total of 5 times during the day. This was at a benefit event for autistic children. Our group had a pickup truck, a Tesla, a C6, a C8 Z51 and some cars I didn't recognize. So if the OP is talking about me this is what I did.
JT
Originally Posted by Street_Carver
The simple answer depends on track type, expectations, risk taking, driver skill etc.
I have done a couple autocross events in my non Z51 and with the summer tires my times compared to other Vettes there and really is only separated by driver skill. For autocross the non z51 is fine. Since its basically a time attack and not consecutive laps around a large track i have had no cooling issues. I think I hit like 205 which I can hit in stop and go traffic.
If you are doing a lead follow and just an "experience" drive on the track that is fine as well.
I would not do a full track day somewhere like VIR in any Stingray TBH but for sure not the non Z51. The cooling will be a problem even on a cool day and the brakes would not be able to hold up either. Even Z51 cars can have cooling issues when running a full open session with a skilled driver really pushing it. Check out the tech portion of this forum, the track rat guys are doing a lot of work to their C8's for full day sessions.
Yep the key is just how aggressive one drives. Running for 10 minutes and letting everything cool should not IMO cause an issue. My biggest concern would be the brake pads. The Base car pads are not designed to handle the higher temps, same with standard brake fluid where when Tracking switching to a race type fluid is recommended. For that matter aggressive Trackers will change to a more race car pad that can handle even higher temps than the Z51 pads.. However could limit speed into corners and brake less aggressively.
Old Jul 9, 2024 | 10:18 PM
Steverino88's Avatar
Steverino88
JT
The early Model T’s and the cars before that, the “Alphabet” cars, were available on colors. When the assembly line was put in place he realized that the black paint dried quicker than the colors. The switch to black was a production decision.
Old Jul 9, 2024 | 10:46 PM
Keppler's Avatar
Keppler
St. Jude Donor '25-'26
Define a track car. Almost any car can be tracked for a HPDE event for fun.
If you want to drive HPDE, as a rookie for fun, all you need is high temp brake fluid. If you drive for fun you will be fine with an instructor.
As you get faster you will need to spend more money. Specifically a dry sump engine would be my first pick. I quickly sold a C5Z and purchased a C6Z.
I was behind several cars, driving HPDE, that had no business being on the that track. One was a base Challenger, another was a Ford Fusion, and the other was a Tesla.
As a HPDE driver, I can easily spot which car does not belong there. Do not be that guy outside of the beginner group. But yes, a non Z51 can drive HPDE for fun while driving conservatively.
Old Jul 10, 2024 | 07:04 PM
jthornton's Avatar
jthornton
Driving at a benefit event to support a good charity you can drive any vehicle with 4 wheels at least at the one I went to. You drive based on the vehicle you're in... if your in a Z51 you might drive more aggressively than if your in a C10 pickup truck. Using common sense you monitor your oil temp and don't brake aggressively if your not in a car with capable brakes. It's all about using your head for more than a hat rack.
JT
Old Jul 10, 2024 | 07:42 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Brake fade will definitely be an issue for the non-Z on the track. Partly because of the smaller brakes and pad material, but also because of the complete lack of cooling vents for the brakes. If one wished to track the base Stingray, even for HPDEs, you'll want higher temp rated pads and the cooling vents from the z51. For autocross I think they'd be fine.
Old Jul 10, 2024 | 11:49 PM
Avanti's Avatar
Avanti
It doesn't matter what the Owners Manuals say about any production, street Corvette. They are not race cars... and yes, that's what "tracking" is all about. Finally, with one model, GM has admitted this. Believe it and go on. Of course, anyone can do as they wish with their own cars.
