Sponsored by: Wheel Design
Launch
Old Jul 9, 2024 | 11:26 PM
ClevelandCorvette's Avatar
ClevelandCorvette
Default Launch
I dont have my C8 yet so can only go by vid observations. What I see is when using launch mode you have a slower acceleration of the line then just mashing the gas. It looks like launch mode stops any and all wheel spin and bogs the start. Am I seeing this correctly?
Old Jul 10, 2024 | 01:01 AM
J-Fly's Avatar
J-Fly
yes, you're seeing this incorrectly. Even when my tires are warmed up....launch control will 9/10 times still give me wheel spin
Old Jul 10, 2024 | 09:00 AM
Spamburger_Hamburger's Avatar
Read up on how launch control works. It uses RPM, clutch, throttle, and other factors to manage wheel spin off the line. When it "bogs at the start" that the car giving what it think is the most power it can without lighting the tires up. You'll still get some spin, but it stops a full burnout. The better the surface and better condition and temp of your tires, the more power it can give and the less it will bog. Most public roads aren't in any condition to give a great launch so a lot of videos you see get some bog as you put it.
Old Jul 10, 2024 | 02:57 PM
randyfl's Avatar
randyfl
I believe you can set wheel spin % on the 2024.
Old Jul 10, 2024 | 06:58 PM
jthornton's Avatar
jthornton
If you have the Z51 there are more options for launch.
JT
Old Jul 10, 2024 | 11:19 PM
Interesting and did not know that.
Old Jul 10, 2024 | 11:23 PM
AzDave47's Avatar
AzDave47
On the Z06 you can also set the launch RPM from 3500 to 5000 and the amount of "slip" from 5% to 15%
Old Jul 10, 2024 | 11:35 PM
Mike Jesse's Avatar
Mike Jesse
Same for the 24 Z/51.
3000-4000 launch RPM in 250 RPM steps.
Slip rate from 5-15% in .5% steps.
Old Jul 11, 2024 | 12:55 AM
C5racecar's Avatar
C5racecar
If you just floor it, the car has an incredible blast of speed and is very impressive because first gear is so low.
My best 0-60 time was 3.5
In Launch mode, wow, maybe it looks like it bogs, but after a few attempts it ran a 2.8.
Floor it or Launch it, both feel very impressive. It may spin the tires with either mode.
They feel the same inside the car but Launch mode is .5 seconds faster.
To Launch
