Sponsored by: Wheel Design
iPhone Hot Spot Autoconnect
Old Jul 29, 2024 | 03:41 PM
Khaberst's Avatar
Khaberst
Default iPhone Hot Spot Autoconnect
Sorry if this has been asked before but I couldn't find a direct answer in the search. Is there an easier way to get my iPhone hotspot to auto connect so the CAR has wifi from my iPhone (not the iPhone having wifi from the car)? Seems like I have to open my hotspot in the iPhone settings every time to get the car to recognize it, even though the iPhone Hotspot toggle is always on.
Old Jul 29, 2024 | 04:30 PM
Khaberst's Avatar
Khaberst
I found this iPhone Shortcut automation idea. Going to give it a shot.
https://www.reddit.com/r/Silverado/c.../auto_hotspot/
Old Jul 29, 2024 | 07:22 PM
khearon23's Avatar
khearon23
I used a similar automated shortcut. It worked fine, but I later switched to an Android device.
For longer trips in my car now, I just use my Solis hotspot. Has it's own battery and I have days and days of data.
Old Jul 30, 2024 | 07:50 AM
StfDrmsRMadeOf's Avatar
StfDrmsRMadeOf
Going out on a limb here but are you trying to use the hotspot as a work around to the my24 navigation subscription? If yes I figured you might be interested in knowing that you can download offline maps that will work without requiring a data connection.
Old Jul 30, 2024 | 03:24 PM
Khaberst's Avatar
Khaberst
Yes, but not really for the maps. I use CarPlay about 100% of the time. Just want it so I can keep the speed limit indicator on the HUD and the annoying not connected plan messages away.
Old Jul 30, 2024 | 04:52 PM
StfDrmsRMadeOf
I can’t help you with the annoying not connected messages, I just ignore those, but the speed limit indicator is an easy fix. You just need to download offline maps, the trick here is the factory installed app doesn’t let you do this, it claims you need a plan to do it. However if you sign into a google account and use the play store to update the app you will then be able to download offline maps.
So unless those data plan warning messages are more annoying than getting the car to connect to your phone I think the download maps is the path of least resistance.
Old Aug 7, 2024 | 05:42 AM
BettyCole's Avatar
BettyCole
1st Gear
I also use CarPlay, all the time.
Spoiler
Old Aug 7, 2024 | 10:07 AM
JRYELLOWCORVETTE's Avatar
JRYELLOWCORVETTE
I still don’t see an answer to the question? Using the iPhone Hot Spot to connect to the Corvette as internet service?
Old Aug 7, 2024 | 10:18 AM
x86guru's Avatar
x86guru
It should just work and the Infotainment system should automatically reconnect to the iPhone's hotspot SSID. Whenever you start the car. It might take a minute or two but it should eventually connect. How long are you waiting for it to connect before deciding to intervene and forcefully select the iPhone's SSID/etc?
Old Aug 7, 2024 | 11:24 AM
papillion's Avatar
papillion
Default Last word on this.......
You can't.
Guess that is two words.
Old Aug 7, 2024 | 12:13 PM
RKCRLR's Avatar
RKCRLR
My 2020 will automatically connect to my phone's (Android) hotspot whenever the hotspot is on and it isn't connected to my home's hotspot. I use a tasking app to turn on my phone's hotspot when it connects to the car's Bluetooth and is charging.
Old Aug 7, 2024 | 12:17 PM
Khaberst's Avatar
Khaberst
Originally Posted by papillion
You can't.
The problem isn't with the car connecting to an SSID it's the iPhone hot spot. Even if you have the iPhone hot spot toggled "ON" if you don't connect within a certain amount of time after accessing that page in the settings it stops providing the SSID. SO to trick the phone I've created an automated shortcut that turns the iPhone hot spot ON after CarPlay is connected. This has been working well the past few drives.
Old Aug 8, 2024 | 02:09 PM
50front's Avatar
50front
The car says i am connected to my home wifi but no internet access. Obviously my home wifi has internet, anyone know how to fix this?
To iPhone Hot Spot Autoconnect
