Sponsored by: Wheel Design
Trunk heat shield
Old Aug 7, 2024 | 06:40 PM
dsnorth2's Avatar
dsnorth2
Default Trunk heat shield
Has anyone tried the trunk heat shield from Blockit Ultralite trunk Heat Shield being sold by Corvette Central? Need to reduce the heat in the trunk.
Old Aug 7, 2024 | 06:49 PM
Glen e's Avatar
Glen e
I looked at the TKO package and realized it was just too expensive. The same insulation plus a gold liner is available on Amazon. Check the other insulation threads here for links.
Old Aug 7, 2024 | 08:08 PM
Kracka's Avatar
Kracka
Here's my DIY project for ~$50 with actually data to back it up:
https://www.corvetteforum.com/forums...for-trunk.html
Old Aug 8, 2024 | 12:36 AM
Shadowman10's Avatar
Shadowman10
I bought the foil backed self adhesive insulation sheets from Amazon. Took the trunk liner out and covered the outside with insulation. I didn’t do any “engineering studies” on the project but the trunk area still gets hot as bejezus.
You have a huge heat source right in front of the trunk area and the muffler system under it. (Remember, heat rises) It’s a freakin oven. No matter what you do short of installing an air conditioner, it’s still going to get hot.IMHO.
Old Aug 8, 2024 | 02:13 AM
Kbmwgt's Avatar
Kbmwgt
Heat Shield products from Summit.
If its good enough for serious heat its good enough for my trunk.
Inside trunk heat shields: Heatshield Products Stealth Shields 810001 (black fabric type)
ENGINE SIDE trunk: Heatshield Products STICKY™ SHIELD:180021 (peel and stick heat shield)
You will notice a difference.
Old Aug 8, 2024 | 10:44 AM
tsigwing's Avatar
tsigwing
Hot AIR rises. Heat moves in three ways: Radiation, conduction, and convection
Old Aug 21, 2024 | 09:49 AM
NA FPC's Avatar
NA FPC
How much weight exactly does this add to the car?
Old Aug 21, 2024 | 11:01 AM
Kracka's Avatar
Kracka
The 48x36" sheet of DEI Reflect-A-Cool that I used weighs 14oz.
Old Aug 21, 2024 | 08:22 PM
sir5list's Avatar
sir5list
I did buy and install the Blockit heat shield and noticed a difference...now, its really warm vs hot. Easy to do and agree, its a bit pricey.
Old Aug 22, 2024 | 12:32 AM
Sixgun95's Avatar
Sixgun95
https://www.corvetteforum.com/forums...runk-temp.html
See my post, #35 and don't look back!
Old Aug 22, 2024 | 06:54 AM
Doubt that will be noticed when it comes to weight.
Old Aug 22, 2024 | 07:11 AM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I have the Block-It kit in my car. On short trips, it works great. Maybe a 10-15* difference from cold. Longer trips, the heat will go above 100 but less than 120. To really maximise cooling in the trunk, I would suggest any type of insulation mentioned here plus a trunk mat. I installed the GM "Jake" mat recently and on the short trip there was no increase in temp from cold. I have not had a chance to take a longer trip to see how much cooler it stays with just the insulation installed.
To Trunk heat shield
