Sponsored by: Wheel Design
Soft close failure
Old Sep 11, 2024 | 06:51 PM
oldbarns1@outlook.co's Avatar
3rd Gear
Default Soft close failure
Has anyone had a problem with the soft close on the hood with their c8 corvette? Mine will not close all the way with the soft close.
Old Sep 11, 2024 | 07:08 PM
Vette_388's Avatar
Vette_388
Has it ever worked correctly?
How many miles and model?
If under warranty, can you just get a dealer to look at it?
Out of warranty I would start with making real sure no obstructions in the seal area, and hinge area. This guy has an explanation of some issues.
Old Sep 11, 2024 | 07:12 PM
CRUZ1NN's Avatar
CRUZ1NN
Soft close on the Frunk will only work on 2024 models. 2023 and earlier require that you push the Frunk lid closed.
Old Sep 11, 2024 | 07:53 PM
Red24Vette's Avatar
Red24Vette
Mine is aggravating! I have had an issue because I leave my frunk unlatched all the time in the garage because of my battery tender. The quickest way I can get my trunk to close is to open it up all the way, then put it down and hit the unlock where ever. Then I have to open it again and then close it to get it to latch.
Old Sep 12, 2024 | 07:25 AM
Salmon057's Avatar
Salmon057
Run your tender cord to the rear of the frunk lid and out at the slot in the corner near the windshield. You can then close the frunk completely.
Old Sep 12, 2024 | 10:17 AM
3rd Gear
Default Locking hood
Got it to close completely. Had to close hood til it latched then had to push down and then push the open button twice under the light while pushing down on the hood. Thanks for everyone’s help.
Old Sep 12, 2024 | 10:30 AM
smithers's Avatar
smithers
It’s because the car goes to sleep after a while. So you have to wake it up to get that to work again. I just hit the frunk open button under the headlight and then it wakes up and works the expected way.
Old Sep 12, 2024 | 10:37 AM
3rd Gear
Default Hood closure
That’s good to know. Strange you can’t just close it without any extra buttons to push.
Old Sep 12, 2024 | 11:21 AM
prb's Avatar
prb
IMO a totally unnecessary widget...I have yet to fail to manually close my '23's hood.
Old Sep 12, 2024 | 11:44 AM
Red24Vette's Avatar
Red24Vette
I've even gone as far as to get in the car and put it in accessory mode. I still have to do what I described above. Maybe mine has a glitch?
Old Sep 12, 2024 | 04:09 PM
Acpantera's Avatar
Acpantera
My 24 closes just fine, drop it and it soft closes. If you leave it open for more than 5 minutes you might have to close it like an old C8
Old Sep 12, 2024 | 04:21 PM
frankjr's Avatar
frankjr
I wake mine up after using battery maintainer by hitting the unlock button twice on my key fob, works every time and no problem with the soft close on my frunk.
Old Sep 12, 2024 | 04:28 PM
v1 rot8's Avatar
v1 rot8
Had an issue with mine yesterday. Soft close would not close it. I pushed down flush thinking it would grab it and lock but didn’t happen. I did the unlock again with remote, then closed it as usual and soft close grabbed it right away and pulled it down.
Old Sep 12, 2024 | 05:03 PM
prb's Avatar
prb
Some nannies are just stupid...this is one of them. What's next, electrically controlled sun visors so you don't have to lift your arm?
Old Sep 12, 2024 | 05:29 PM
Kevin A Jones's Avatar
Kevin A Jones
Same here!
I mean really, how much energy does it require to manually latch your frunk or engine compartment lid. Totally un-needed IMO!
Old Sep 12, 2024 | 07:08 PM
Red24Vette's Avatar
Red24Vette
I'll give that a try next time!
Old Sep 12, 2024 | 08:13 PM
Scruff Vette's Avatar
Scruff Vette
I thought it was just me and an intermittently working soft close mechanism . Good suggestions here that I'll try . Coming from a '23 to a '24 I don't really see a need for this change. My '23 latch was stiff and took a good push to shut for a short while but became very easy to close with little effort.
Old Sep 12, 2024 | 08:50 PM
Acpantera's Avatar
Acpantera
lol, awesome idea!
Old Sep 12, 2024 | 09:19 PM
Bob_T's Avatar
Bob_T
Well, now that you mentioned it... If they did devise such a mechanism, it would have two electric motors per sun visor (one on each side of the sun visor), with fragile plastic gears that instantaneously strip if you inadvertently forgot they were motor driven tried to put it down by hand, with at least 4 sensors per visor (two encoders on each sun visor to be sure that the two motors did not get out of sync and have the visor rotate down, or back up, lop-sided and two other sensors for "overtorque monitoring" (one on each motor on each side of each visor) so that the computer doesn't let motors don't hurt themselves if they did get out of sync. It would have its own specific OBD code so that if the Electronic Sun Visor System (ESVS) were to malfunction, the BCM would report and register that code, throw a check engine light, and illuminate the familiar DIC message saying "REAR AXLE SYSTEM OFF - SERVICE ESVS SOON".
And then............ when you have waited your couple of weeks for your appointment time to finally arrive at the dealer, they have the car for a week and call you late afternoon on Friday and to tell you "we found the problem - one of your sun visor motors failed, and the replacement motor is on backorder. We should have it in about 2 weeks. Unfortunately we cannot let you take your car back because it is unsafe to drive with a non-functional driver's side sun visor, especially if you travel east to west any time after noon. We'll give you a call when your car has been repaired and ready for you to pick up".
To Soft close failure
