Fuel Management System CEL
I turned around and drove home without further issue, and the car continued to drive normally under light to moderate acceleration. After getting home, I stopped and started the car, but the light remained on. After several hours, I tried to remote start the car and it did not work. The car would just click twice and sit there. I got in and started the car normally, but the CEL light remains on.
The car has 2500 miles and the only modification is a Borla S-Type exhaust that was installed about a month ago. I only buy 93 octane premium gas from the same Exxon station near my house and the tank is at 3/8 full.
Has any one seen this message? Are there troubleshooting steps to determine more information on the message and is there a way to reset the light? Any thoughts or ideas would be appreciated. @Andybump ?
If needed, I can take it to the dealer on Monday, but I would like to avoid the trip if there is a simple explanation and fix.
I cannot find anything specific, but it seems to be related to the valves on my Borla S-Type based on other posts on this forum with similar codes.
@Andybump
Tom
In most cases, the Borla system re-uses the 4 actuators. They are removed from the OEM system, and then mounted on the Borla system. They normally always require a learn procedure after they have been disturbed - that would be the case even if the actuators were removed and put back on the OEM muffler.
The valves themselves are part of the muffler system - you just re-use the actuators. It is possible that a valve in the muffler is stuck or sticking as well. In that case - the re-learn will not work. It would be a defective valve. Other points of failure are the actuators and the harness and connectors leading to them.
Tom
I reset the DTC with the cheap scanner for now and the CEL is gone. I ordered a Launch Creader Elite that will allow me to perform the relearn if the CEL light returns.
As mentioned above, the shop did the relearn, but I read in other posts it might have to be done several more times. I bought the Launch scanner to do it myself if the issue returns.
The CEL did not return, so I hope the issue from yesterday was a one-time event. If not, I will do the valve relearn with the Launch Creader scanner.
