To adjust the Bose volume speed control in the C8 Corvette, you'll need to access the Audio Pilot feature. Here's how to do it:
Accessing Audio Pilot
Go to the infotainment system's audio settings menu.
Look for an option called "Bose Audio Pilot" or similar.
Adjusting the Settings
Once you've found the Audio Pilot setting, you have two main options:
Turn it on: This will activate the speed-sensitive volume control.
Turn it off: This will deactivate the feature, requiring manual volume adjustments.
It's important to note that Audio Pilot works differently from traditional speed-sensitive volume controls. Instead of simply increasing overall volume as speed increases, it uses in-car microphones to analyze interior noise and adjusts specific frequency ranges to compensate for road and wind noise
"Speed-dependent volume control adjusts your audio system's sound output to the current speed of your car ."
Searched the owner's manual...but could have missed it....where can I shut off this 'feature'? Thanks!
The info provide above about the Bose Audio Pilot is correct. But in what document did you find the terms in red? That does not appear in the 2024 Owners Manual - to my knowledge- there is no "speed dependent volume control". Only the Bose Audio pilot feature which works as described by monitoring the ambient noise in the cabin, not the speed of the car.
OK here is the goofy part. I added an aftermarket subwoofer and in order to defeat the "Engine Sound Enhancement" which was causing feedback, I unhooked the diver side mic. This dsiables the autio pilot.
Now, randomly, I get the option to change Speed Sensitive Volume to low/medium/high. I have no idea what triggers this option and it doesn't happen every start.
When i does, I set it to medium and it works great
Weird.
I think I remember you mentioning that before. So, you never saw that message before you disconnected the microphone, right? And, I could not find that option (speed dependent volume control) mentioned in the manual (although the audio pilot is mentioned).
Great that you now know how to turn that setting off. Just curious why you would turn it off? Ever since my C4 days I have found that feature to be handy versus manually turning the volume up when driving the car.
Not answering for the OP, but some folks think that since the audio pilot adjusts not just volume, but "equalization" (which I think means the "volume" in different "audio frequency bands"), the frequency response is no longer "flat" (if that is even a good thing), and so the music is distorted. But the thing is, the Audio Pilot does nothing if there is no ambient noise, supposedly. So it only kicks in when the car is moving and there is lots of cabin noise. Its kind of a loosing battle to create "perfect" sound in a moving car. Still, I do not dispute those who say they can tell a difference and prefer it to be off. They know what they are hearing.
Correct. Normally the audio pilot switch is displayed. But occasionally, randomly it is replaced with a SDV slection of low/meduim/high. Really strange
And you said it actually changes something right? I just checked and both the 10 and 14 speaker systems include the Audio Pilot feature according to the Bose website for corvette C8. Its not necessarily surprising the software to create an "unused" display is in the infotainment system, but its a little more surprising if the processing to do speed dependent volume control is in there as well as the Audio Pilot processing. I have seen reports on the forum of other odd display, such as a GMC display - so its obvious they develop multi-use software.
Yes, that's how I discovered it. First time is kicked in it was set to high and I noitced a big change in volume with speed. So I looked in the audio menu and backed it down to medium.
