Code P12F0
Agree….I think I’ll start a dialog with Borla in advance to see where that leads. Pretty sure I haven’t hit that million mile mark as of yet. But it’s the AFM, not the exhaust.
In giving him background on what I have done so far (relearn), he said he has never heard of a tool that can do the relearn other than the factory tool from GM. In speaking further, he did say there are tools out there that can flip the valves open/close, but not calibrate (relearn) as the GM tool has a wide tolerance as actuators/valves are like a box of chocolates (you never know what you’re going to get). He said it should go on the GM tool and that will decide the way forward.
So it shall be….
When you initiate the relearn you can actually see the actuators opening and closing the valves if you have someone in the car hitting the learn button and you are looking at the exhaust through the mesh of the rear bumper.
Being it's bank 2 it's the passenger side. I bet when you do the cylinder deactivation relearn you will see the passenger side afm valve stay open for way longer than the drivers side one. If the actuator arm was not adjusted to the proper length the valve might not open and close properly, triggering this issue. There are several other reasons why this issue might be triggered. But a replacement passenger side afm valve section would be the worst case solution.
http://www.corvetteexhaustsystems.com
sales@corvetteexhaustsystems.com
201-575-0861 (cell to call or text)
Your Ultimate Resource For Headers, Exhaust Systems & more for Corvette! I carry Corsa, Kooks, ARH, Borla, Billy Boat, Akrapovic, Capristo & Much More
https://youtu.be/4TKTCxKdmT0?si=E4JzBH7c8GrNHTxE
Borla is saying that this tool only opens and closes the valves and states whether the valves successfully (or not) met the calibration limits stored in the ECM…it does not adjust the limits and that only the GM tool can. I’ve had the ATAK installed for nearly 2 years (Dec 12, 2022) and about 6000 miles. When my dealer installed the system they did a relearn as part of the install. So I hopefully will find out what’s up next week.
Edit: Add from the Service Manuial, here is the "description" of the Cylinder Deactivation Exhaust Control Valve Learn Procedure: "This procedure triggers the control module to learn the values of the component: Q15 Exhaust Flow Control Valve"
I do not disagree that there is going to be some tolerance in the open and closed positions. We must assume that the once the positioned are learned, then the system that detects an issue with the valves will include the tolerance in the algorithm. But, I also believe that detection of the out of range is sensitive. I say that because even if an actuator is simply removed, then remounted to the same muffler valve, its position may be disturbed enough that the learn procedure is required.
"Note:
You may notice an exhaust tone change due to the AFM system activation, or during certain driving conditions to meet Federal noise pass-by
regulations. Review the cylinder deactivation exhaust flow control system operational modes listed below for additional details.
1. Stealth Mode: Exhaust tailpipe valves will be closed at all times when the engine is running.
2. Tour Mode: Exhaust tailpipe valves are closed when the engine is idling and during normal/non-aggressive driving. Valves open during
aggressive driving.
3. Sport Mode: Exhaust tailpipe valves are open when the engine is idling and during most driving scenarios. See note above.
4. Track Mode: Exhaust tailpipe valves are open at all times. See note above."
I checked the part numbers for the exhaust valve actuator for my 2021, and also the 2024 Z06, and the part numbers are the same (84896575) and are said to fit 2021-2025. So that suggest to me that that the actuators are already capable of assuming variable positions (if the Z06 has that feature) if so commanded by the control signal. The part numbers are different for the 2020 model. I think that is because in 2020, while the Cylinder Deactivation Exhaust Control Valves included a feedback signal to the controller (which is the Fuel Pump Power Control Module), that feedback path is not shown in the schematics for the Tailpipe Exhaust Flow Control Valves. I think in 2021 and later years that path was added and the part number sere changed. I also read that in a post - but I wll not be able to find that again.
So I’ve filed the paperwork with Borla for replacement…..let’s see how that goes and how far they go in standing behind a product that lasted about 6,000 miles.
But, had a long chat with the Corvette Master mechanic about the issue in which info not posted anywhere was shown to me regarding my very problem. I will post this info after my dialog with Borla concludes one way or the other…..it will raise eyebrows.
The car is completely driveable and no discernible degradation in performance, etc. I probably won’t put 200 miles on it for the rest of the year as rain is on its way and destroys the value of a C8 (that’s humor BTW).
