Sponsored by: Wheel Design
2023 Map SD Card
Old Dec 25, 2024 | 10:11 AM
jthornton's Avatar
jthornton
Default 2023 Map SD Card
Is there any procedure for changing the map SD card. The owners manual has no information about changing the map SD card.
Maps
The Nav application requires a map database to run. It is stored on an SD card that is connected to the infotainment system. If the
map database is not available, a missing SD card error message will be displayed.
SD Card Error Messages
. The SD card has initialized for the first time: “Once initialized, this SD card can only be used for navigation in this
vehicle.” Make sure the SD card switch is in an upward position.
. The SD card is not working properly: “SD card is not functioning properly. (Error Code).”
. The SD card is not paired with the existing system: “This SD card is not valid in this vehicle for navigation. See Owner’s
Manual for more detail or visit your dealer. (Error Code).”
. The SD card has been removed from the slot: “SD card has been removed. (Error Code).” Make sure the Nav SD card is in
the slot. Touch Confirm to resume after the initialization error message. For the other messages, touch OK to return to the
Home Page.
If any errors continue, see your dealer.
Not a whole lot of info...
JT
Old Dec 25, 2024 | 10:33 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I just updated to the 2024 kmap. It is very easy to change....resides in the console. Every year it goes on sale in Nov. Picked it up for $99.
Old Dec 26, 2024 | 03:33 PM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Just unplug the old one and plug in the new one. It's in the center console SD slot.
Old Dec 26, 2024 | 05:57 PM
jthornton's Avatar
jthornton
Thanks, after reading the info that came with the card and the manual it seems none of that applied as @MarkMeHopeful said just replace the old with the new with the car off.
JT
To 2023 Map SD Card
