Sponsored by: Wheel Design
What...Wait..E85? Seriously
Old Dec 30, 2024 | 06:00 PM
combatninja's Avatar
combatninja
C8s run fine on FlexFuel tune and pump 'E85'. Put it in quotes because rarely is the actual ethanol content over 70% on it. C8s will show gains up to about E65-70.
Old Dec 30, 2024 | 06:24 PM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
What flex fuel tune?
Old Dec 30, 2024 | 08:18 PM
combatninja
Any reputable C8 tuner can have the ECM unlocked by HP Tuners and set you up with FlexFuel capability using a DSX kit. This is not rocket surgery.
Old Dec 30, 2024 | 08:36 PM
BearZ06's Avatar
BearZ06
Okay, but that's another story. This thread seems to be about the stock C8, is higher octane really any advantage?
The C7 Z06 with GM'S ECU update installed and all C7 ZR1's utilize 100 octane without tuning.
Old Dec 30, 2024 | 11:21 PM
S'vette's Avatar
S'vette
I occasionally run e35 in my vette. 5 or 6 gallons of e85 and the rest 93 oct. The e85 is about a dollar a gallon cheaper too. I cant really feel a daily difference when running it but in the summer I will try a launched control and see how it does. I already did a 2.9 with just the normal gas and that was before catback. So will see in a few months as Im in Washington state and its gloomy and rainy as hell for awhile. question though, how may miles should I run the new mix before trying the launch?
Old Dec 31, 2024 | 06:26 AM
449er's Avatar
449er
CF Community Team
Originally Posted by Whoad_way_down
Lower fuel costs. Yep...Spend a ton on the car hate giving it away at the pump. From what I have read...Not going to change a thing and will keep pumping the fuek.
E85 fuel is cheaper than gasoline BUT you will get less fuel mileage per tank so you won't save any money if that is your idea, you will get a bump in horsepower with a proper tune & a proper flex fuel system
Old Dec 31, 2024 | 10:41 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I did it once by accident on one of my daily driver cars. I didn't panic. In a mile or two I got a check engine light. Once I dropped to 3/4 full, I added high octane. I did that every time I got to 3/4 full and a few days later the check engine light cleared and I never had any problem in the future. The computers are very robust, and I learned that it will adjust the timing to compensate, in this case retard. The check engine appears as the computer has hit near its limit of the timing spec window. My Vette mechanic explained it will not damage anything as most all fuel system components in most cars are designed to handle alcohol within reasonable limits but still noted the fuel recommended by GM should always be used.
Old Dec 31, 2024 | 11:54 AM
CP's Avatar
CP
The country should not be putting food into gasoline. End of story.
Old Dec 31, 2024 | 12:21 PM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
Politics aside I respectfully disagree, rain makes corn, corn makes horsepower, or however that country song went.
Old Dec 31, 2024 | 02:45 PM
MitchAlsup's Avatar
MitchAlsup
Converting food into fuel makes both the fuel and the food cost more.
The only reason there is ethanol in fuel is because politicians voted for it to get the farm-vote.
Old Dec 31, 2024 | 03:30 PM
Travlee's Avatar
Travlee
So by your statement corn and potatoes shouldn't be made into vodka either
Old Jan 1, 2025 | 12:30 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Originally Posted by SMOKN C8
I am not telling you what to put (or not) into your own car. I am telling you that the other thread I linked above has a lot of good information in it about using E85 to get to E30 in these cars.
Why Closed-Loop Systems Can Handle E30
1. Adaptive Fuel Management:
  • Closed-loop systems use oxygen sensors and real-time feedback to adjust air-fuel mixtures. This allows them to compensate for the higher oxygen content in E30, which can result in a leaner burn if unadjusted.
2. Octane Benefits:
  • E30 has a higher octane rating (around 94-96), which allows the engine to handle advanced timing and increased compression without knocking. This can improve performance and efficiency in engines designed to take advantage of higher-octane fuel.
3. Government and Industry Studies:
  • Studies, such as those from the National Renewable Energy Laboratory (NREL) and Department of Energy (DOE), suggest that many post-2001 vehicles (approved for E15) can tolerate E30. Testing often shows no significant wear or damage, with some vehicles even achieving cleaner emissions.
Links to studies:
  1. https://digitalcommons.unl.edu/chemengall/142/
  2. https://www.energy.gov/eere/vehicles...icant-effects?
  3. https://www.governorsbiofuelscoaliti...arable-to-e15/
  4. https://www.governorsbiofuelscoaliti...l-legislation/
Most modern vehicles can run E30 effectively, the legal and warranty implications are the key reasons automakers stick to E10/E15 recommendations. If you’re willing to accept these risks, the technology in your car is more than capable.
And not one not one of those links will restore your warranty when you use more than the 15% ethanol fuel limit the owners manual says. The word "many" I highlighted in your post doesn't say "including the C8 Corvette," or even "most GM vehicles."
Originally Posted by OLD_GOAT
No different than putting on a catback, tune, or other bolt on parts that can also void the engine warranty.
LOL, It's WAY different than a bolt on mod. No catback is going to degrade any other parts of the car. Ethanol just might.
Old Jan 1, 2025 | 12:38 PM
  #33
Red Mist Rulz
Vodka's not food?
Old Jan 1, 2025 | 01:14 PM
  #34
Travlee's Avatar
Travlee
Originally Posted by Red Mist Rulz
Vodka's not food?
It is for me right now....
Old Jan 1, 2025 | 06:27 PM
  #35
OLD_GOAT's Avatar
OLD_GOAT
I mentioned catback, tune, and other bolt on parts in the context all could void the engine warranty.
Old Jan 1, 2025 | 09:06 PM
  #36
davelv's Avatar
davelv
Re ethanol corn and food - ethanol is not made from human edible corn nor does growing its source corn affect food prices. Additionally modern processes create ethanol with more energy than it takes to produce and reduces oil usage by over 1 million barrels per day reducing the need for military use to procure/secure oil. It originally was a gimmee to farmers 15 years ago but today is very beneficial to environment and security.
