Sponsored by: Wheel Design
C8 device in Tucson
Old Feb 10, 2025 | 06:33 PM
Jofido's Avatar
Jofido
Default C8 device in Tucson
Is there a recommendation regarding routine service for the C8. I just got a bill from Watson Chevrolet for over $1800 for an oil change, filter, transmission service, rear axle service, and air filter. This for a 3year old C8 in excellent condition and less than 6,000 miles.
Old Feb 10, 2025 | 06:46 PM
Zymurgy's Avatar
Zymurgy
Moderator
What specifically was the "transmission service". Filter and fluid change for the DCT is expensive. If it was filter only, you overpaid. If it was filter and fluid change, the price was reasonable given everything else done. Your Owner's Manual has the service requirements.
Old Feb 10, 2025 | 07:05 PM
SoCal C8's Avatar
SoCal C8
Livin the Life
2024 C8 of the Year Winner - Modified
Rear axle service? Nothing in the manual regarding that “service”.
Old Feb 10, 2025 | 07:25 PM
Jofido's Avatar
Jofido
filter, fluid and $775 just for the transmission service. They said the rear axils required fluid per the computer as did the air filter.
Old Feb 10, 2025 | 07:48 PM
Zymurgy's Avatar
Zymurgy
Moderator
Post a copy of the work order showing what was done, parts/fluids used, time, etc. That will allow us to completely understand what was done and give you guidance.
At 3 years, it was due for DCT fluid change. Hopefully you have had the engine oil/filter changed per the OLM which would require at least every 12 months.
Old Feb 10, 2025 | 08:20 PM
Jofido's Avatar
Jofido
Here is a copy of the bill.
Old Feb 10, 2025 | 09:13 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Hmmm, Zymurgy would know, but is the "Delivery Date" 1/1/21? And does it equate to "In-service" date?
Old Feb 10, 2025 | 09:33 PM
kenrobb's Avatar
kenrobb
I just had my oil/filter changed.
Labor rate was $200/hr; they charged me $44.95 labor.
Filter was $6.00 as yours
Charged me for 8 quarts = $79.60; yours was 7 qts.
Then $6.74 enviro chg.
Total was $137.29 + tax = $144.91
No mention of rear axle service.
We are sort at the mercy of the dealers.
Old Feb 10, 2025 | 09:44 PM
Macman3509's Avatar
Macman3509
2025 C8 Stingray of the Year Winner - Unmodified
What is an axle flush? Nothing in the C8 Owner's Manual about flushing the axle. Bogus charge?
Old Feb 10, 2025 | 10:46 PM
Zymurgy's Avatar
Zymurgy
Moderator
The only thing that is suspicious to me is the "axle flush". Never heard of it.
They used the correct oil and DCT fluid. They also used correct oil filter and DCT filter. Their labor rate of $189 is reasonable.The DCT fluid is expensive unless you buy it yourself from RockAuto. Their charges are reasonable.
Old Feb 10, 2025 | 10:50 PM
Jofido's Avatar
Jofido
I have had my car serviced every 12 months, including oil changes and filter at Watson Chevrolet. Nothing like this bill.
Old Feb 10, 2025 | 10:58 PM
Zymurgy's Avatar
Zymurgy
Moderator
I bet you've never had the DCT service before. That is $1330 of your total. Plus the bogus axle flush of $185. Those 2 items are $1515 of your total, not including tax and shop fee. Oil/filter change was $148 which is probably similar to your previous service visits. There's no question that the DCT service is not cheap.
Old Feb 10, 2025 | 11:56 PM
I can understand your surprise at the total cost. But it doesn't take long to run up the costs when you have $775 in labor alone for the transmission service and another $520 in parts for that service.
Old Feb 11, 2025 | 06:53 AM
449er's Avatar
449er
CF Community Team
What does the owner's manual say for rear axle service intervals? I wouldn't think that a 3-year-old car with 6,000 miles would need that
Old Feb 11, 2025 | 07:07 AM
qwazipsycho's Avatar
qwazipsycho
Axle flush?? Axle flush?!! WHAT?! Did you replace the muffler bearing too?
Old Feb 11, 2025 | 07:43 AM
proeagles's Avatar
proeagles
I believe the manual calls for a trans flush at 3 years.
Old Feb 11, 2025 | 08:27 AM
SoCal C8's Avatar
SoCal C8
Livin the Life
I believe the fluid in the eDiff is the same as the transmission and is flushed when the trans service is performed. If the “computer” said the rear axle needed fluid, it sounds like a code may have been stored for the “Rear Axle Off”. If that’s the case then it should have been covered by warranty.
If not, I’m surprised they left the below service off your order……
To C8 device in Tucson
Old Feb 11, 2025 | 08:28 AM
Red24Vette's Avatar
Red24Vette
To cut through the chase, the C8 has a transaxle. A transaxle is a transmission and differential in the same case using the same oil!
Old Feb 11, 2025 | 08:51 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I pay $130 for oil change and $640 for the trans service at Sands Chevy in Surprise, AZ. Sands is working hard to become the premier Corvette dealer in the Valley.
Old Feb 11, 2025 | 09:15 AM
ArizonaZ06's Avatar
ArizonaZ06
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
Good to know thanks. Surprise is not too long with our new 202 Westside to I10 freeway
When you say Trans Service does that include DCT filter and fluid?
