C8 Free Warrenty coverage
Sounds like engine oil and filter change only.
A while back I was told by somebody at the dealer the DCT oil and filter change was free after 7000 miles and was also covered. Is that true?
I don't have 7000 miles yet. Can I count on two free oil changes.
John
You get 1 free oil/filter change any time you want within the warranty period.
You are required by warranty to have your DCT filter changed at 7500 miles (+/- 500miles). This IS covered under warranty.
You can use either or both services for free once. Any time you want. BUT you still are required to change DCT filter at the specified mileage no matter if you did it at your leisure.
Most C8 owners wait until 7500 miles or so and have both oil/filter change and DCT filter change at GMs expense.
If dealer is pushing for a change now I'd look for another dealer.
Read you owners manual concerning your
WARRANTY
John
https://static.nhtsa.gov/odi/tsbs/20...00117-0001.pdf
"Q: The customer wants the filter replaced early, can I
use this warranty coverage to pay for the replacement?
A: No, the odometer must have at least 7,000 miles to
use the factory covered maintenance. If the customer
wants the filter replaced prior to the GM recommended
schedule of 7,500 (+/- 500 miles), it is at their expense."
In any case, I suggest you just get it done now. But...from a filter loading point of view (not a warranty point of view), if you change it at 4400 miles, I do not believe you are in danger of a filter overload. As distasteful as it is, I would go ahead an change it now - while you are just 300 miles over.
So....there is a tech-link article, dated July 2024, that contains this wording (but beware):
"Engineering recommends that the filter be changed as close to 7,500 miles (12,000 km) as possible – plus/minus 1,000 miles (1,600 km) should not be detrimental."
That very same tech-link article also contains these words:
'If the canister filter is replaced more than 500 miles (800 km) prior to the initial 7,500-mile (12,000 km) break-in period, the filter still needs to be replaced again within plus/minus 500 miles (800 km) of the 7,500-mile (12,000 km) service interval. "
And, perhaps more telling....I received the letter from GM about the required maintenance, stating the +/-500 mile window on or around Nov of 2024, so thats a good 4 months more recent than the tech link article. I know this because I posted it on the forum the same day I received it:
https://www.corvetteforum.com/forums...quirement.html
So, unless the dealer has something in writing, from GM, like an official service bulletin, or a superseding letter from GM stating that the maintenance requirement has changed, I do not believe that one can rely on that "+/- 1000 miles should not be detrimental", that appears in a tech link article that pre-dates the letter from GM.
I did see, on the forum, where that Conti person claimed the larger window in video - but they never said what the source was. Unless something different is produced - I think it probably came from that tech link article - which is came well before the letter from GM.
And that leads in to the other problem - that came up in this thread. The required maintenance schedule itself, in the Owners's Manaul's, with regard to the first DCT filter change, has been a bit of a moving target. It was originally listed in 2020-2023 manuals as being "at 7,500 miles". There was no stated tolerance around the "at 7,500 miles". Owners and dealers had to make up their own acceptable mileage window. Is 1000 miles close enough? There are examples on this forum of dealers telling owners that 4500 miles. It was not until 2024 that the requirement was fully clarified to mean between 7000-8000 miles, even if done earlier. The "even if done earlier" was not previously stated either. So, for all those 2020-2023 owners that do not participate in any forum, they had no knowledge of "clarification". Until mid or late 2024, when GM sent letters to all owners. For many, who followed dealer advice, it was already too late. Given that the Warranty verbiage referred them to their owners manual - that lacked this information - can GM really deny a warranty claim if the get filter changed as soon as they can?
All that said, I agree with you - the verbiage in the tech-link article with the larger window does not appear in anything ever made available to owners by GM, and would not prevail.
John
I believe that the included maintenance for MY 2025 has changed. My reading of the included maintenance is now limited to only the engine oil and filter (no longer the DCT filter and fluid top off). This service must be completed within the first 12 months or 12,000 miles. This is from the Chevrolet Build and Buy website (under the Warranty Tab).
And FYI, the "Tire Rotation" is swapping the tires left to right and vice versa, NOT front to rear or a cross wise rotation due to the different size tires front and rear...
https://www.corvetteforum.com/forums...on-filter.html
Anyway, the answer is yes, some of the prior forms mentioned the DCT filter change. I capture several from other forum posts. All are Corvette specific - or at least say Corvette up front. See attached examples.
The 2020 version says 1 year (the extension to 2 years happened in 2021 and was retroactive). It does NOT mention the free DCT filter change.
The 2021 version says 1 year (but it was extended to 2 years and was retroactive - it was extended for my 2021). It DOES mention the DCT filter change.
The 2023 version shows 2 years and mentions the DCT filter change.
Your 2025 (already posted above) version shows 2 year and does NOT say the DCT filter change is free, only that it needs to be done.
I do not have a 2024 CA form, but we know that it was split according to the April 2024 bulletin. Did that get reflected in the 2024 form?
So......????
