Sponsored by: Wheel Design
DCT filter question
Old Mar 8, 2025 | 06:27 PM
hyprsprt's Avatar
hyprsprt
Default DCT filter question
Hello, I own a 23 that I purchased in may of 32 I currently have around 4500 miles on the car and 2 months short of 2 years and the car is due for a trans filter change, but I read somewhere on the forum that GM changed it from 3 years to 3 years for the free replacement/service is that correct?
Old Mar 8, 2025 | 07:18 PM
EvanD's Avatar
EvanD
CF Community Team
For your year it’s two years but you’ll have to do it again at 7000-8000 miles at your cost.
Old Mar 8, 2025 | 07:58 PM
hyprsprt's Avatar
hyprsprt
o wow that’s crazy that I will have to change it change it again after only 2500 miles but I guess it is what it is but thanks for the info
Old Mar 8, 2025 | 08:26 PM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
Yes, another GM senseless decision. Why not give all C8’s 4 years to reach 7-7500 miles if they want it done so bad, especially since it would still be under warranty anyway. I’m in same place with 4590 miles and a March 22nd deadline. I’m not even sure GM will do the transmission with less than 7000 miles as of the 24 models. I’ll know soon.
Old Mar 8, 2025 | 09:16 PM
RKCRLR's Avatar
RKCRLR
I don't understand why they couldn't extend the free DCT filter change to match the duration of the 5 year powertrain warranty.
Old Mar 8, 2025 | 09:35 PM
sjw91's Avatar
sjw91
BTW, you'll be due for the DCT fluid change in a year. If you can do 3000 miles by then, do the filter at the same time.
Old Mar 9, 2025 | 08:48 AM
Andybump's Avatar
Andybump
No.
The change to which you refer applied to 2024 model years and was NOT retroactive. That change split the free service into an engine oil/filter change that can be claimed within 2 years, and a DCT filter change that can be claimed within 3 years. That change also added a minimum mileage of 7000 to claim the free DCT filter change.
Prior to that, for 2020-2023, it is/was a combined service that expired in two years, with no mileage limit. Many of us had to claim the free service well before 7000 miles (I got mine at 2500 miles). Some dealers try to tell customers that there is a minimum mileage limit for those model year (2020-2023) but that is not the case.
Old Mar 9, 2025 | 11:35 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by Andybump
No.
Andy as you note, it's NOT retroactive. And for the OP, Yep have to change it again before you reach 8000 miles (7500+/- 500 miles.)
I was going to TEST the other mention in the announcement that it's NOT free unless you have 7000 miles. The Service Manager thought they could get reimbursed. BUT since my E-Ray is now driven in Rain, instead of having the DCT filter changed, as I did in my 2020 C8 year 1 at ~3000 miles, I just had the engine oil/filter changed on GM's dime year one with 4500 miles.
  • With my 2020 C8, car was somewhat jerky when crawling into my garage (keeping the driver's door mirror tip gap to garage door molding to ~1 inch) at ~2 to 3 mph. Until I reached ~1000 miles after which it was perfectly smooth. I thought that was probably due to the high spots wearing in 1st gear as it MUST slip below 4 to 5 mph or the engine would stall. Wanted the free Flush prior to the free DCT filter change to remove possible clutch "stuff." Knew I would have to have it done again before I reached 8000 miles (which I did year 3.)
  • With my E-Ray I still crawl into the garage watching that mirror tip to wood door molding and rubber weather seal gap. Frankly even more so as that wide rear fender gets close as after making a "K" turn from the driveway as it's NOT perfectly perpendicular.. In fact the garage door rubber weather molding is painted house white and paint can transfer to that left rear fender (ask how I know? But comes off easy!) No jerky movement from day 1 with the E-Ray. Perhaps they improved the multidisc clutch plate surface finish?
I'll have between 7000 and 8000 miles this year and will have the DCT filter with Flush done on GM's dime when I'm at that mileage.
PS: For OP, would even be worse if you had ~6500 miles and had it done! Yep GM's warranty, GM's rules. Can always self insure as I do for many things. Just be ready to spend ~$20,000 when GM turns down a warranty DCT replacement!
BTW I think that narrow DCT filter change window is specified by Tremec as part of their supplier agreement. In the case of a warranty failure, Tremec probably has to supply a new DCT AND pay whatever GM gives the dealer to install during. Not so easy to think GM will just cover.
Old Mar 9, 2025 | 11:48 AM
Andybump's Avatar
Andybump
  • With my 2020 C8 it was somewhat jerky when crawling into my garage (keeping the driver's door mirror tip gap to garage door molding to ~1 inch) at ~2/3 mph until I reached ~1000 miles after which it was perfectly smooth. I thought that was due to the high spots wearing in 1st gear as it MUST slip below 4/5 mph or the engine would stall. Wanted the Flush prior to the DCT filter change to remove possible clutch "stuff." Knew I would have to have it done again before I reached 8000 miles (which I did year 3.)
  • With my E-Ray I still crawl into the garage watching that mirror tip to wood door molding and rubber weather seal gap. Frankly even more so as that wide rear fender gets close as after making a "K" turn from the driveway it's NOT perfectly perpendicular.. In fact the garage door rubber weather molding is painted house white and paint can transfer to that left rear fender (ask how I know, but comes off easy!) No jerky movement from day 1. Perhaps they improved the multidisc clutch plate surface finish?
I'll have between 7000 and 8000 miles this year and will have the DCT filter with flush done on GM's dime when I'm at that mileage.
BTW I think that narrow DCT filter change window is specified by Tremec as part of their supplier agreement. In the case of a failure, they probably have to supply a new DCT AND pay whatever GM gives the dealer to install. Not so easy to think GM will just cover.
@JerryU , if you look at your warranty coverage in your chevy account, does it show the two separate "free" (better referred to as "included") services for your 2024? I attached mine for my 2021 so others will know what I am asking about. I only have one of course since its a 2021, now claimed and expired. I am also wanting to see the same thing posted for a 2025 model to confirm that the change carried over - the bulletin that announced the change "starting in 2024" says the applicable model year is 2024-2024.
To DCT filter question
