I've read where the LT2 engine has a special "bleeding" procedure when engine coolant is added.
I can't find any reference to it in the Manual.
Any thoughts on this?
I'm not aware of the coolant bleeding procedure. I did add the aux V09 drive side radiator. I just ran the car up to temp, let it cool added coolant and repeated. It did a fine job of bleeding the system itself. Unlike my Porsche Boxster which requires you to pull a vacuum on the system and suck the coolant in.
The bleeding process is not simple and time consuming. I had to have it done in Ohio on my way home from Louisianna. 2-3 hours if I remember correctly as they need to bring it up to operating temps, and let it cool back down, and essentially go throught the refill, heat cycle a couple of times. If you're just topping off, I don't think it's an issue.
I have not read the manual, but common sense is that the coolant overflow tank is the highest point in the system, so it should bleed out any air bubbles.
But, If you drain the system, that makes it a whole lot more complex.
Radiators up front and on the sides, that could be really complicated, forget about common sense, you need to read the manual for that.
Topping off, not such an issue, but if you have drained any part of the system, it can get to be a PITA. If you don't use the vacuum refill method or the "run engine and bleed several times" process, then it's an uphill battle since any air bubbles tend to remain hidden away in the system. In my case things would look normal but once the rpm's reached around 2000 then the cooling system would start doing crazy things.
The front radiators have bleed ports, but they're not accessible under normal operation and are really only needed if you replace major components. The system will self bleed over time. One tech buddy told me to leave cap off overnight with a shop towel over it and the air would migrate out itself. Said they generally do a good job self-bleeding and you don't need to mess with the front ports.
To just top off the system you don't need to do anything... just check it cold in the morning before you run the car and add fluid just over the "full" plate that you can see looking down into the reservoir. I don't even top off w/ coolant... I just used filtered water from my fridge.
Be warned, some of the cars are over-filled from the factory. One of my C8s spilled coolant all over the place even taking cap off cold in the morning. It was filled to the max of the reservoir and still had some residual heat from using it the day before. Makes for a sticky mess... I just ran the garden hose down in that area.
The method in the owner's manual is for adding coolant. What I'm curious about is the procedure for replacing the coolant per the service schedule. I have an eBay copy of the service manual but I can't find the coolant replacement procedure (doesn't mean it isn't in there). I'd like to see the GM service procedure for replacing the coolant.
I can't find it in mine either. Its called out many times (Cooling System Draining and Filling) but the procedure itself, under that name, is not there. And yes there are bleed caps up front - I have seen illustrations of that - but I can find that either right now.
What follows is a summary of the coolant fill and bleed procedure in the 2021 service manual. It is 28 steps.
Remove the covers (30 in the front.
Put absorbent rags around the auxiliary heater inlet and outlet intermediate hose cap. This is on both side of the frunk. Use needle node pliers to rotate the caps CCW and pull up. If coolant flows out put the cap back on. Note that is you've drained the system completely then this will occur when you are filling it.
Disengage the radiator inlet hose retainer and remove the inlet hose connector cover. This is next to the brake fluid reservoir. Again, when coolant comes out put the cover back on.
Next fill the system with a 40/60 mix of coolant until coolant comes out of the vents above. Close the vents
Start the engine. With AC OFF allow the engine to run for 10 minutes. Shut off the engine. Let the engine cool down (approx 10 minutes)
Repeat all the steps above.
Withe AC OFF, allow the engine to idle until one of the aux radiator outlet hoses becomes warm near the radiator, the coolant temp should approach 185F. If not repeat the steps above,
