New Wheels: What could go wrong?
Came home thinking I would clean up my calipers, slam the new wheels on, and go for a drive.
Wait a minute! The new wheels are slightly smaller at the surface where they contact the hub/rotor.
There is some rust on the rotor that was covered up by my old wheels. !@#$% That is going to show behind these new wheels.
Get out the sandpaper, Scotch Brite, and caliper paint. Several hours later sanding masking, painting. I'm ready to install.
I'm really happy with the new wheels. Buying wheels is not easy, there are so many things to consider.
ALT Velocity Rotary Forged, I was not sure about the offset, but it looks great on the car.
these offset numbers put the wheels perfectly flush if you are replacing stock w/ aftermarket ones…but plan to use the stock tires.
19X8.5+34MM | 20X11+45MM
It's more than I wanted but there were no options. I will probably warm up to the wide look.
It is OK, but when I see tires so close to the edge, it reminds me of a teenager with an old Camaro and deep wheels that were not made for the car, and the tires sticking out an inch or more.
That is not the look I want.
