Sponsored by: Wheel Design
Traction control intervention / jumping
Old Apr 24, 2025 | 05:51 AM
SonofaBish's Avatar
SonofaBish
Default Traction control intervention / jumping
Just started experiencing an issue with my z51 this morning.... the traction control is kicking in and causing a jumping sensation for seemingly no reason.... highway off ramp or any medium radius turn... don't really need to be turning hard.... happens turning both directions... agnostic to mode, and even happened when I turned traction control off
Only issue with the car currently is that the left front tire pressure sensor isn't reading and I need to get to the shop and get it reprogrammed, but i can't for the life of me imagine that's the issue..... plus it's been like that for a couple weeks.
Only recent changes to car have been
- new Stance wheels, with factory pilot sport 4S tires
- soler performance throttle controller
But both have been on for a month
Any ideas on where to start troubleshooting?
TIA!
Old Apr 24, 2025 | 06:08 AM
SonofaBish's Avatar
SonofaBish
Forgot other recent repair.... passenger dash and airbag replaced bc it was delaminating... by the Chevy dealer....
again, don't see it being a factor, but i don't know how intertwined c8 systems are ... if it were a Porsche, it could explain it 🤣
Old Apr 24, 2025 | 08:22 AM
Andybump's Avatar
Andybump
TIA!
How do you know that what you are experiencing is caused by Traction Control. Are you getting the TCS/ESC light that flashes when the TCS and/or the StabiliTrak/ESC system is actively working? Have you checked for DTCs?
Old Apr 24, 2025 | 08:28 AM
SonofaBish's Avatar
SonofaBish
yes, that's exactly what's happening....
When that light flashes, I can feel it grabbing the brakes.... went around some sharper turns and it was grabbing pretty hard. One turn even felt like it applied a brake and held it
Old Apr 24, 2025 | 08:48 AM
Andybump's Avatar
Andybump
OK. But, any diagnostic trouble codes (DTCs)? Some codes can exist without setting the MIL (aka CEL) on the dash.
If no codes, its going to be more difficult to diagnose. I'm sure you realize that kicking in like that is a safety issue - like the opposite of stability control.
The system uses a bunch of sensor - it can detect wheel slip, and also acceleration in various directions (yaw rate, lateral acceleration and longitudinal acceleration sensors). Issues with tire pressure monitoring can affect it. I'm not sure how, but here are examples of DTC descriptors related to stability control:
DTC Descriptor
Vehicle Stability Control Disabling Inhibited by Tire Pressure Monitoring
Vehicle Stability Control Disabling Inhibited by Limited Slip Differential
Vehicle Stability Control Disabling Inhibited by Suspension Control Module
Old Apr 24, 2025 | 11:27 AM
arbitrator's Avatar
arbitrator
Check wheel speed sensors.
Old Apr 24, 2025 | 11:35 AM
RKCRLR's Avatar
RKCRLR
An undetected TPMS sensor can cause traction control problems unless all TPMS sensors are removed. I'd get that fixed first and see if the problem goes away.
Old Apr 24, 2025 | 12:34 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
If you are unable to identify the source of the traction control jolting and kicking, it is best to take your Corvette to a Chevrolet dealership for a diagnosis. It may be due to your tire sensor being out, but we won't know for sure until it is seen by a GM-technician. Should you need help connecting with one in your area, feel free to email us at socialmedia@gm.com with your Username and Forum title in the subject line.
Old Apr 24, 2025 | 12:36 PM
SonofaBish's Avatar
SonofaBish
DTC Descriptor
Good call, i have a Creader in the car, so I'll check. With no CEL I didn't figure that would be causing my issue. But def worth looking.
OK fair enough ... just haven't been able to get to the tire shop.. appreciate the insight!
Old Apr 24, 2025 | 02:11 PM
SonofaBish's Avatar
SonofaBish
Pulled the codes... on the BCM it shows a internal malfunction on all 4 tire pressure sensors... 3 of them are reading on the display, though.
C-1171-49
C-1172-49
C-1173-49
C-1174-49
Old Apr 24, 2025 | 02:47 PM
Red Mist Rulz's Avatar
Red Mist Rulz
DTC Descriptor
The line in red would seem to indicate that traction control is tightly integrated with tire pressure. Which makes complete sense: if one of your tires is flat, it's going to have a lot less traction than normally inflated tires.
Old Apr 24, 2025 | 03:38 PM
Andybump's Avatar
Andybump
C-1171-49
C-1172-49
C-1173-49
C-1174-49
There ya go. You need to start there and resolve that. Will probably solve your problem.
Old Apr 24, 2025 | 06:25 PM
combatninja's Avatar
combatninja
I blame anything called "Stance" put on the car.
I'll see myself out now....
To Traction control intervention / jumping
