Sponsored by: Wheel Design
5 Year Maintenance Costs
Old May 19, 2025 | 10:23 AM
  #41
EvanD's Avatar
EvanD
CF Community Team
Maybe they detailed your car for the shop supplies?
Old May 19, 2025 | 10:45 AM
  #42
tbasco 6's Avatar
tbasco 6
His Vette Tech must be real messy, mine charges $25 which I assumed was for the medical gummies he needed to get him thru the day.
Old May 19, 2025 | 07:08 PM
  #43
guitarman1's Avatar
guitarman1
Think about it, you know they purchase these mundane items in bulk greatly reducing costs, so that's almost a profit of $730 for every 10 vehicle that enters their service dept.
Can you imagine how much money that will come to over the course of a year at a busy dealer service dept.
I just looked at my receipt more carefully. Here's what it says:
"Shop Material: A charge equivalent to 10% of total repair order charges is included for materials used on your vehicle. Applicable supply items are nuts, bolts, washers, pins, aero sprays, solvent, rags, towels, battery cleaners, etc."
Old May 19, 2025 | 08:12 PM
  #44
EvanD's Avatar
EvanD
CF Community Team
Even itemized it's stupid crazy.
Old May 20, 2025 | 08:51 AM
  #45
Red Mist Rulz's Avatar
Red Mist Rulz
Originally Posted by RKCRLR
While brake fluid absorbs water most modern systems are "sealed" with respect to using a diaphragm that expands/contracts instead of venting. As you noted some manufacturers just have you check the fluid. There are relatively inexpensive moisture meters for brake fluid and there are test strips similar to pool test strips.
I live in a relatively dry environment and once my vehicles are out of warranty I test the brake fluid with a moisture meter and inspect for discoloration. If moisture is present or the fluid is discolored it gets replaced.
Brake systems have always been sealed. The fluid still absorbs moisture through the rubber brake lines.
My edit in the post you quoted makes it clear: the 5 year requirement is for all cars, not just those in Severe Service. Just as it was in the earlier manuals. "Owner Checks and Services" is not a subheader to Severe Service. It's a new section at the same level.
Originally Posted by Red Mist Rulz
Old May 20, 2025 | 09:43 AM
  #46
Andybump's Avatar
Andybump
Yes - agree. After looking more carefully, it is an additional section at the same paragraph level - and not a subsection under Severe Service.
Old Nov 27, 2025 | 12:22 PM
  #47
Cubs-Vette's Avatar
Cubs-Vette
1st Gear
Default 2020 Corvette Stingray Z51 5 year Service
I would like to know if anyone lives in the Phoenix, AZ area and what dealership they used for the 5 year service items and cost. (Brake flush, coolant flush, and front lift service flush) Thanks
Old Nov 27, 2025 | 02:26 PM
  #48
Zymurgy's Avatar
Zymurgy
Moderator
I had mine done in September at a local recommended Chevrolet dealer (Huffines Chevrolet - Plano). Engine coolant change was $485.00 (included replacing the 20 psi tank cap) and the brake fluid change was $210.00. Oil/filter change was $118.35. All fluids, parts and labor included. Shop charge was $40.00.
