MP3 playlist example
#EXTM3U
..\Scattered Music\Shared Music\The Beatles - 1967-1970 Disc 1\01 The Beatles - Strawberry Fields Forever.mp3
..\Scattered Music\Shared Music\The Beatles - 1967-1970 Disc 1\02 The Beatles - Penny Lane.mp3
..\Scattered Music\Shared Music\The Beatles - 1967-1970 Disc 1\03 The Beatles - Sgt. Pepper's Lonely Hearts Club Band.mp3
..\Scattered Music\Shared Music\The Beatles - 1967-1970 Disc 1\04 The Beatles - With a Little Help from My Friends.mp3
..\Scattered Music\Shared Music\The Beatles - 1967-1970 Disc 1\05 The Beatles - Lucy in the Sky with Diamonds.mp3
..\Scattered Music\Shared Music\The Beatles - 1967-1970 Disc 1\06 The Beatles - A Day in the Life.mp3
I thought the extended M3U format header (and associated extended data) was causing the issue, but I can see Rock is using it without issue. I removed the upper-level directory "C:" stuff in my initial attempt (I think I created the original playlist with Windows Media Player), but as I'm imagining the file in my head, I'm thinking I started the lines with "\" rather than "..\". My folder structure looks similar (a slew of folders with the CD's name in the root directory, with a bunch of numbered mp3s in each), so I should be able to get rid of the initial "".
So, right now my file looks similar to this (using Rock's and Walt's example data)... extended header, followed by extended info and location of each song:
#EXTM3U
#EXTINF:187, Strawberry Fields Forever - The Beatles
#EXTINF:201, Penny Lane - The Beatles
I will continue playing with it...
Last edited by Dan Hintz; May 27, 2025 at 09:58 AM. Reason: Forum keeps getting rid of my backslashes
I thought the extended M3U format header (and associated extended data) was causing the issue, but I can see Rock is using it without issue. I removed the upper-level directory "C:" stuff in my initial attempt (I think I created the original playlist with Windows Media Player), but as I'm imagining the file in my head, I'm thinking I started the lines with "" rather than "..". My folder structure looks similar (a slew of folders with the CD's name in the root directory, with a bunch of numbered mp3s in each), so I should be able to get rid of the initial "".
#EXTM3U
I usually select random playback. I've found that I would sometimes hear some of the same songs over again but other songs often would never play. However if I did some skipping forward and back through songs then other songs that I haven't heard in a while would play randomly.
Sometimes the car loses it' memory and random playback gets deselected, and songs start playing from the first song of the first album until I select random again. Then the above process starts over.
I can play all of the mp3s, so that's not it. It recognizes the playlist file itself, as the playlist itself shows on the playlist tab. It just displays "USB device cannot be found" yadda yadda yadda on the playlist tab under the playlist filename.
On another topic, which I have brought up, has to do with being able to scroll past more than 9 items while the car is moving. I don't use Play Lists, so I am curious if you are able to scroll past more than 9 items (songs, albums, artists, etc...) while the car is moving. I get the "Scrolling locked while the car is moving" message on my screen.
Tony, No, I'm locked out of scrolling while in motion, too. The device not found message has been a constant under the playlist tab... it will show the playlist filename, so it recognizes the list itself, but there's nothing but the error message below it.
Someone PMed and suggested that this being GooglePlay (and and Android, a.k.a. Linux app) might be the cause, so I swapped all of my Windows-style backslashes with forward slashes. No joy. My next attempt will be to surround directory names with quotes to deal with spaces, and then a test with escaping the spaces using additional backslashes.
Perhaps I should try to find a connection within Google to ask this question...
So I got something to work, but I don't know what it was.
My last attempt seemingly failed... choosing it from the menu brought up nothing of consequence. And I selected it multiple times over the next few days without change.But here we are months later, and I accidentally selected it while trying to hit one of the other menu options... and it populated the screen with the songs. One would think that a playlist, coming in at a few kB in size, would be easy/fast to read (digitally). But evidently it was taking its own sweet time indexing the files.
Now I need to pull the stick back out and look at what format I used to create it.
#EXTM3U
I hit the steering wheel button and say "Play this song or this album" and it plays. No drama. Every song album there is for like 12 dollars a month.
And why should I pay $12 per month for music I already have and paid for?
BTW, I also use Spotify both on the car's built-in app and on my CarPlay AI box (although not the paid version).
