Sponsored by: Wheel Design
Performance Exhaust
Old Jun 2, 2025 | 07:28 AM
Nick's 2023 C8's Avatar
Nick's 2023 C8
4th Gear
Default Performance Exhaust
I have a 2023 C8 with a non performance exhaust system. I purchased a Borla Atak used. I understand I won't be able to use the valves the way they are designed to be, but just want them in the open position. Are they shipped in the open are closed position?
Thank you in advance.
Old Jun 2, 2025 | 10:28 AM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Factory NPP is open by default, so Borla should be the same.
Old Jun 2, 2025 | 03:42 PM
Rocketmanwpb's Avatar
Rocketmanwpb
To my knowledge the factory exhaust is only totally open at start up then goes to a lower decibel setting. If you don't have a hook up to the car I would check with Borla to see if they have some type of controller solution for your situation.
Old Jun 2, 2025 | 03:51 PM
EvanZR1's Avatar
EvanZR1
Originally Posted by Rocketmanwpb
To my knowledge the factory exhaust is only totally open at start up then goes to a lower decibel setting...
The default position is open, the reason it closes after startup (in Tour) is the valves are sent a close signal by the computer.
Old Jun 2, 2025 | 04:01 PM
Andybump's Avatar
Andybump
Its been reported a few times that with the valve actuators removed, the valves in the muffler will be open. Even if the Borla was different, I think all that you need to do is just add piece of wire in the appropriate place to hold them open.
Are you planning to re-install the Cylinder Deactivation Exhaust Flow Control (AFM) Valve actuators? If not , you will need simulators for those because even non-NPP systems have those valve and actuators. I personally would re-use them, but some prefer not to.
Old Jun 4, 2025 | 04:33 PM
Corvetteexhaustsystems's Avatar
Supporting Vendor
Yes the valve's default position is open
To Performance Exhaust
