tinting my windows
doing this job later today, I am not near my car. I have a simple question: when you open the door, the windows drop a half inch or so, will hitting the door window switch pop them back up with the door open?
Good question - give it a try. Not sure if that will work or not.
Close the latch on the door frame with the door open and the glass will go up. You can use a plastic trim tool or screwdriver. You will need to reverse the procedure to close the door when finished, the latch wont spring open by itself.
