Do any one know of a vender that has offered a replacement for the bottom panel underneath the DCT filter with an access door. Would really be nice and worthwhile.
Im sure you know the answer to this but it's easy to cut out and make your own. Here is a video of my access hatch (V Vette access) that gives clarity on how to do it. Any questions please ask. v
All I did was to take careful measurements of where the best location would be.
Drop the belly pan.
Skillfully using a cut-off wheel remove the section.
Found a 12" Stainless Steel hinge and fit the the plate using pop rivets.
Longest part was removing the belly pan!
Drop the belly pan.
You had to take it ff anyway so why not do the panel IF your a DIYer-no brainer!
If you have the right measurements. is it really necessary to take off the belly pan?
I just did it on my new Vert but it was shaky. I put car on QJ, and used magic marker for cutout location. Then removed all bolts EXCEPT the front ones and let it hang off back. Using a jig saw upside down I cut opening BUT luckily I wore protective eye wear (Should have used full face shield) as shaving few all over. I supported the cover pressing heavy sheets between frame and cover so when cutting it would not flap... I would remove panel if I were you as I have done the access panel (Both ways) several times now.. Just take it off and do it.
