Sponsored by: Wheel Design
Errors on shutting engine off
Old Sep 14, 2025 | 09:26 AM
DerbyCity's Avatar
DerbyCity
Default Errors on shutting engine off
Shortly after I shut down the engine, 0 oil pressure warning was displayed, one start allowed, and the start engine button did nothing. I sat there for a while and opened the door and shut it. It then started for me . I believe it was a glitch, has anyone had similar issues?
Old Sep 14, 2025 | 09:52 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
If you are able to start the car (i.e. FOB close to car BUT not inside) and you drive off with NO KEY when you stop it gives you ONE start so you can get home!
Possibly need a new FOB battery as a week battery could let you start but when you shut the car off it did not "see" the FOB.
Old Sep 14, 2025 | 10:02 AM
papillion's Avatar
papillion
Default Two Step
From the 2022 manual on p10: If the key fob battery is too low to start the car, place the key in the center console cupholder closest to front of car, with the mechanical key end facing up, and start the car normally; replace the key fob battery as soon as possible.
Old Sep 14, 2025 | 10:33 AM
OneMoreVet's Avatar
OneMoreVet
St. Jude Donor '25-'26
Brand new 26 here with 200 mi, same thing happened. Not knowing the fob came out of my pocket and fallen between the door and seat. I thought it was still in my pocket when I tried to shut the car off and got that message. I left the car running and started searching for the fob knowing it had to be somewhere because I just got through driving for a 1/2 hour. When I found it and went ahead and shut the car off. Hasn't happened since so hopefully this isn't a preview of things to come.
Old Sep 14, 2025 | 11:00 AM
JerryU's Avatar
JerryU
Originally Posted by papillion
FOB Battery Change
Good How To Video, BUT key issue is where you are buying batteries, I got burned with my C7 buying a Top Brand battery from Amazon. Some products, like batteries, are >50% bootlegged on Amazon. Bootleggers are Smart they pick top Brand Names!
Old Sep 14, 2025 | 07:10 PM
DerbyCity's Avatar
DerbyCity
Did it also display in red 0 oil pressure?
Old Sep 14, 2025 | 07:56 PM
patton's Avatar
patton
St. Jude Donor '09
these tips are good to know just in case ....thank you
Old Sep 14, 2025 | 08:51 PM
OneMoreVet's Avatar
OneMoreVet
No it did not. Never saw oil pressure on DIC on this or my other car which was a 24 SR LT3.
I'm sure it wasn't a fob battery issue
To Errors on shutting engine off
