Sponsored by: Wheel Design
Front trunk closing
Old Sep 19, 2025 | 03:59 PM
davanz's Avatar
davanz
Default Front trunk closing
On my new 2026 C8, the rear engine compartment lid shuts the same as the rear trunk on my C7 cars. That is, I lower it gently down and then with a little pressure, the latching mechanism takes over and pulls it shut. But the front compartment doesn’t seem to have this feature. To close it I have to almost “slam” it before I hear the final latching. What is the normal operation of the front compartment lid shutting?
Old Sep 19, 2025 | 04:16 PM
50front's Avatar
50front
Drop the front trunk lid from about 12" up and the motor will take it from there. It motor will time out pretty fast if you leave it open requiring hitting the unlock button on the remote to wake it.
Old Sep 19, 2025 | 05:05 PM
LeJerk's Avatar
LeJerk
Gently close it until it makes contact with the latch, then gently give it a push down and it'll close the rest of the way.
Old Sep 19, 2025 | 05:32 PM
green2000's Avatar
green2000
The 2026 is an improvement over the 2020. I find it closes the same as the trunk. I think it takes longer to open than the 2020.
Old Sep 19, 2025 | 06:14 PM
Micster's Avatar
Micster
2024 SR. While it shouldn't require "training", after a couple months of imperfect closes, I discovered a drop from 15" will activate the "pull down" every time. I do this because I'd rather not need to push the lid down if possible/ easy.
Old Sep 19, 2025 | 06:29 PM
patton's Avatar
patton
St. Jude Donor '09
My new 25 e is acting up [fronk] raises up but then acts like a 65 chevy having a second manual hood release . I have to hit the remote a couple of times for it to release it will also raise up after closing too on its own . I do not wanna get stuck with it on the road so maybe a dealer visit .
Old Sep 19, 2025 | 06:34 PM
Phil1098's Avatar
Phil1098
I was told by the rep at the museum to drop it and when it hits hard enough, the power pull down will take over. I close mine by hand and push down until it makes the first latch, then the power works the rest of the way. The thing crashing into it just seems wrong to me.
Old Sep 19, 2025 | 06:45 PM
patton's Avatar
patton
St. Jude Donor '09
I rarely have it not work pulling it down i use either a drop of finger flick down ....its getting it to fully un-latch and then it raises up on it own
Old Sep 19, 2025 | 09:17 PM
3LZR21U's Avatar
3LZR21U
Banned Scam/Spammer
Close it to. Nudge it down a tad. Soft close will take over.
p.s.
Frunk soft close started with 2024 MY, IIRC.
Old Sep 20, 2025 | 02:38 AM
Bob Paris's Avatar
Bob Paris
Good question and I wonder why it is not covered in the owners manual
Old Sep 20, 2025 | 08:21 AM
Andybump's Avatar
Andybump
You are being sarcastic here, right?
"To close the hood, either drop the hood
about 0.3 meters (1 ft) from the latch,
or lower the hood until it is secured in
the latch and push briefly on the outside
of the top of the hood until the latch
clicks into engagement, then let go of
the hood. The hood will then close
automatically."
Old Sep 20, 2025 | 09:29 AM
Joe's Eray's Avatar
Joe's Eray
Exactly the same as what I do.
Old Sep 21, 2025 | 01:36 AM
dstewart51's Avatar
dstewart51
The pull down could be out of sync, that is, already retracted and only latching, not retracting. Close the Frunk, then use the remote key to open, it should not pop open but lift then release, if it pops open its out of sync. To get it in to sync, just close and activate the release a few times, I had this happen to me.
Old Sep 21, 2025 | 07:04 AM
NewOldFart's Avatar
NewOldFart
On my 25 there have been a couple times when it was as if the vehicle front trunk mechanism had gone to sleep. Frunk would not lock, then I would do something like open the door and it would go back to working normal.
Old Sep 21, 2025 | 12:20 PM
DA KAR's Avatar
DA KAR
Active Streak: 90 Days
you can also hit the unlock button on your remote and then push down again for the frunk motor to work again.
To Front trunk closing
