Sponsored by: Wheel Design
Tires always leaking
Old Sep 24, 2025 | 05:23 PM
jmoody66's Avatar
jmoody66
Default Tires always leaking
I have a 22 c8, I kid you not....every other day I will go out and a tire, random side, will be down to 21 lbs. I don't think someone is jacking with me but air stability is my problem. Stock tires, still plenty of tread.
anyone experienced this?
Old Sep 24, 2025 | 06:04 PM
YO-EL's Avatar
YO-EL
Are you using the tire pressure on the screen or a hand held gauge?
Have you verified the pressure loss with a tire gauge?
My point, if you measured with a pressure gauge and all is good, then the display tire pressure may have a glitch.
If indeed an arbitrary tire is down 10 psi overnight, that certainly is strange.
Do you park it outside? If yes, them someone is definitely messing with you.
If its parked inside, and arbitrary different tires go down 10 psi overnight, I have no idea what to tell you bro!
Old Sep 24, 2025 | 06:06 PM
Tonycan's Avatar
Tonycan
You may have a bent wheel.
Old Sep 24, 2025 | 06:38 PM
Zormecteon's Avatar
Zormecteon
Just to be sure, perhaps a security camera. These are not too expensive, need no wiring, or subscription; that is buy it, put it up and no more cost. Both are solar wifi. Get alerts on your phone when breached as well as a recording.
NFI
https://www.amazon.com/eufy-Security-Activated-Detection-Waterproof/dp/B0CB7SCQRG/ref=sr_1_1_pp?crid=1X6GKVSWBJGXR&dib=eyJ 2IjoiMSJ9.zyz44THBTp4a_ZCToPXmVHqDGGvDT-t6A_WwbMqMGmbw8GXDHXzNpyaHCvpAlxdzfVRfXT _7rUsadirmVf2N-OU-o-u6ST_vdTCaSmSGJfujzannSuuPfeAejeXO4XUoi5 pjDILGH11JId9JakV2xXRpLkhZrXuRovMfjBEzPP DziIJshbdMxBcRAIH5QgwPMwD6yYdixf8Cq9BVwd sD0_1Iu9goPM0NlPWrfALNIR8.EpQANIq3kogvB8 ouCf2T7GMLW1T9on98pTvdww8-Rd8&dib_tag=se&keywords=eufy%2Bsecurity% 2Bcamera&qid=1758753385&sprefix=eufy%2Ca ps%2C189&sr=8-1&th=1
OR
https://www.amazon.com/eufy-Security-Wireless-Surveillance-Compatible/dp/B0CLFVC6ZG/ref=sxin_14_recs_zoco_stores_brand_identity_bs?content-id=amzn1.sym.7d2e00dd-9358-4f89-aca0-04685eb73811%3Aamzn1.sym.7d2e00dd-9358-4f89-aca0-04685eb73811&crid=1X6GKVSWBJGXR&cv_ct_cx=eufy+security+camera&keywords=eufy+security+camera&pd_rd_i=B0CLFVC6ZG&pd_rd_r=d12ba247-b5df-4090-900c-4ed2b4b2ee0b&pd_rd_w=WlMGI&pd_rd_wg=8wPgR&pf_rd_p=7d2e00dd-9358-4f89-aca0-04685eb73811&pf_rd_r=XGFKF9ZQZPHCS7G8ZMNB&qid=1758753385&sbo=GW1QB%2BmqAsHTPf1jTZRSDA%3D%3D&sprefix=eufy%2Caps%2C189&sr=1-1-5f457e4f-4cf5-45bd-948b-58563dcb013a https://www.amazon.com/eufy-Security-Wireless-Surveillance-Compatible/dp/B0CLFVC6ZG/ref=sxin_14_recs_zoco_stores_brand_identity_bs?content-id=amzn1.sym.7d2e00dd-9358-4f89-aca0-04685eb73811%3Aamzn1.sym.7d2e00dd-9358-4f89-aca0-04685eb73811&crid=1X6GKVSWBJGXR&cv_ct_cx=eufy+security+camera&keywords=eufy+security+camera&pd_rd_i=B0CLFVC6ZG&pd_rd_r=d12ba247-b5df-4090-900c-4ed2b4b2ee0b&pd_rd_w=WlMGI&pd_rd_wg=8wPgR&pf_rd_p=7d2e00dd-9358-4f89-aca0-04685eb73811&pf_rd_r=XGFKF9ZQZPHCS7G8ZMNB&qid=1758753385&sbo=GW1QB%2BmqAsHTPf1jTZRSDA%3D%3D&sprefix=eufy%2Caps%2C189&sr=1-1-5f457e4f-4cf5-45bd-948b-58563dcb013a
Mike Campbell's Avatar
Mike Campbell
They don't leak but if your car sits for a month the air pressure drops because cold air pressure drops but drive the car and they'll quickly go up.
Old Sep 24, 2025 | 07:04 PM
Call me Q's Avatar
Call me Q
An easy thing to check is the valve stem - make sure the core is screwed in tight. I had a tire leak this way.
Old Sep 24, 2025 | 09:10 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
As one said above either bent cracked wheel a good possibility.
Old Sep 24, 2025 | 09:20 PM
jmoody66's Avatar
jmoody66
verified by handheld pressure gage, I park outside, drive daily, only have 1 bent wheel but, ironically, it doesn't leak. I drive it daily and it will be ok for a couple of days and then bam....one wheel will be at 21 lbs.
I may get a camera setup just to see cuz this isn't funny...lol
I'm going to change all the cores for fun.
Thanks for all the input guys...I was just curious.
Old Sep 24, 2025 | 09:39 PM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
Yes, I had a loose valve stem. It should be tightened to 62 in/lb. Just try tightening it and see if the nut turns easily. Compare with other 3.
If not, you need to mix a little dish soap with water in a spray bottle.
My sister-in-law had a slow leak but hers took 2 months to loose 5 lbs. Turned out to be a tiny nail or a piece of wire. It took a lot of time spraying and looking for the small bubbles while spinning the tire on the car.
Old Sep 24, 2025 | 10:57 PM
C5racecar's Avatar
C5racecar
They gain 3-4 pounds when driving on a hot day. Bad valve stem? Bent wheel? Nail or slow leak? Neighborhood pranksters.
Have the tires ever been off these wheels? Are they the original rims. Did somebody screw up the bead when changing tires.
Old Sep 25, 2025 | 05:57 AM
YO-EL's Avatar
YO-EL
I think some here are misreading the original post...
He's losing air, not from the same tire, but from DIFFERENT tires, DIFFERENT sides, every other night he stated...
So the issue isn't a valve stem, or tire bead....
I feel someone's messing around... as its parked outside....
Old Sep 25, 2025 | 07:03 AM
Kenny94945's Avatar
Kenny94945
Random tires. different tire every day?
Loose valve stem seals or Schrader valves may be the easy answer.
Bent rims, bad tire seals, small punctures... a shop with a dunk tank could be low-cost step two.
But.... random act of "vandalism"... perhaps.
I recall seeing "locking" valve stem caps, which could be worth buying.
Blue Lock Tight... I would not recommend.
Good luck.
Old Sep 25, 2025 | 07:55 AM
ProudZowner's Avatar
ProudZowner
https://www.facebook.com/share/v/17DJdP2NbR/
Check 3:17
Old Sep 25, 2025 | 07:58 AM
ProudZowner
Well my tech skills suck. That didn't work. It showed a parrot pecking at the valve stem to enjoy the air blast...
Old Sep 25, 2025 | 11:04 AM
TrevVette's Avatar
TrevVette
I had a tire leak (not Corvette) only when the tire was in a certain position. I could go for weeks without losing air and then at other random times it would be down a few pounds. I finally found a small nail in the tread. My assumption was that it only leaked when the tire was flexed in a certain position while parked. However, this seems unlikely if there is more than one tire with this random leaking problem.
Old Sep 25, 2025 | 10:03 PM
PurdueDoc's Avatar
PurdueDoc
Originally Posted by ProudZowner
Old Sep 28, 2025 | 10:42 AM
Sir Nuke's Avatar
Sir Nuke
I had one wheel/tire that did this.....had to check it about once a week or so.....same one every time. finally took it to a tire shop, broke the bead.....cleaned the bead sealing surface on both sides.....lubed the tire like normal when putting tires on, it never leaked again.
To Tires always leaking
